Old photo Solid rubber tires
Herb Iffrig
Topic author - Posts: 1762
- First Name: Herb
- Last Name: Iffrig
WayneJ
- Last Name: Jorgensen
- Board Member Since: 2013
Re: Old photo Solid rubber tires
Looks like the White House in the far background.
Wayne Jorgensen, Batavia, IL
1918 Runabout
1918 Runabout
5 lug demontables. I'm sure we have seen that brand but I don't remember.
Great photo. I agree with Wayne. D.C.
It may be a 1921 DC plate with a smaller number.
I believe Firestone demountables utilized 5 lugs.
WayneJ
Looks like it has "Department of State" written on the side. Looks like the Eisenhower Executive Office Building in the near background. Originally known as the: "State, War, and Navy Building".
1918 Runabout
1918 Runabout
Joe Bell
- First Name: Joe
- Last Name: Bell
I just recently repaired a Chain driven T that had "New" solid rubber tires on it they where made in Canton Ohio.
After several trips to the net I found this:
https://www.shorpy.com/node/5270?size=_original
With the double row of holes it may be the same brand.
They put a new slant on solid rubber tyres. With that many holes they are hardly solid any more. I wonder how much better they rode than true solid rubber tyres? At least they should be longer wearing, and less troublesome.
- First Name: Dallas
- Last Name: Landers
I bet with mud in the holes on one 1/2, they were out of balance a bit.
Luxford
- First Name: Peter
- Last Name: Kable
By the late 1920's solid rubber tires were being targeted by governments world wide because of the damage they were doing to roads.
It was determined a vehicle with such tires caused 5 times the damage to roads compared to pneumatic tires which with advances in technology were becoming as good or better than solid rubber tires. The designs such as those with the holes however superior would have been banned along with all the others.
WayneJ
This is a great picture. The more I look at it, the more I see. If you look directly above the vehicle roof, you can see the top of the West Wing of the White House. When you enlarge it, you can see where the wall bulges out for the Oval Office. Cool!
1918 Runabout
1918 Runabout
Virtus
- First Name: Paul
- Last Name: Robertson
- * REQUIRED* Type and Year of Model Ts owned: Ford model tt 1921 right hand drive
The tyre industry has now gone full circle! These tyres are in great demand in the construction industry. The old adage applies "there is nothing new under the sun"!
