Straight axle questions
Mike Lebsack-Iowa
Last Name: Lebsack
* REQUIRED* Type and Year of Model Ts owned: 11Torpedo, 11 Roadster, 13 Touring, 14 Roadster, 14 Touring
Board Member Since: 2008
Post by Mike Lebsack-Iowa » Tue Aug 18, 2020 7:35 am
We are machining a pair of new straight axles and have a couple questions. We have a pair of badly worn originals but would like to verify two things.
1. What width should the key way be? Our original is very worn and wide.
2. What is the relationship of the pin or bolt hole to the keyway? It appears to be roughly 90 degree or has a centerline perpendicular to the centerline of the keyway.
Please private message me or email me at lebsackmike@gmail.com
Last Name: van Ekeren
Re: Straight axle questions
Post by Kerry » Tue Aug 18, 2020 8:22 am
maybe of some help, key for the straight axle 1/4x 1/4 x 4-9/16, Bore on the hub 1-1/16 x 4-3/4
Mike Lebsack-Iowa
Last Name: Lebsack
Post by Mike Lebsack-Iowa » Tue Aug 18, 2020 8:37 am
Thanks Kerry, every little bit helps. Mike
Dan B
Last Name: Blaydon
Post by Dan B » Tue Aug 18, 2020 9:54 am
