T-6574-X removal...
NU2theT
Topic author - Posts: 214
- Last Name: Wendt
- * REQUIRED* Type and Year of Model Ts owned: 1926 Fordor
T-6574-X removal...
I needed to remove my old head lamp sockets from the housings and found that the pictured 1/4" drive 1/2" deep socket fit perfect to drive it down with out damaging the head lamp shell.
Jim_PTC_GA
- Last Name: Fisher
- * REQUIRED* Type and Year of Model Ts owned: 1924, 1925-ish
Re: T-6574-X removal...
I'm so glad you posted this. I found myself this morning wondering how to replace a damaged one on the T I'm rebuilding and remembered this post. Thank you for taking the time to post it.
Just give me time to Rust and I'll be good as new.
Wabi-Sabi
Using some WD-40 to lube the socket really helps in removing the socket from the shell.
I then used a rubber hammer carefully to loosen it and simply pushed it out by hand.
NU2theT
- Last Name: Wendt
It's rewarding to know this little tip help someone else. I had sprayed the socket housings the day prior with the PB blaster, as you can see mine were pretty rusty.
