1922 Center Door project
Will_Vanderburg
First Name: William
Last Name: Vanderburg
Post by Will_Vanderburg » Sun Aug 23, 2020 7:04 pm
Haven't posted on my project in a while. I just got more pieces this past weekend.
The running gear after I jacked it up and put four replacement wheels on it. The original wheels were rotted through.
The engine didn't turn when I got it, now it does. I oiled the bores and with a 2 x 4 scrap, I lightly tapped each piston using a 2 pound hammer
parts you don't see are 5 demountable rims that need blasting and coating.
Last edited by Will_Vanderburg on Sun Aug 23, 2020 7:10 pm, edited 1 time in total.
William L Vanderburg
1922 Center Door Sedan
Will_Vanderburg
First Name: William
Re: 1922 Center Door project
Post by Will_Vanderburg » Sun Aug 23, 2020 7:06 pm
Hub replacement
hub had a retrofitted Chevrolet cap
Will_Vanderburg
First Name: William
Post by Will_Vanderburg » Sun Aug 23, 2020 7:09 pm
The frame had an Ames horn on it. Stored under a plastic tub for I don't know how long. I don't even know if it works. Been raining on and off today and the place where I can test it is kind of cramped at the moment.
horn cap interior as found
horn interior as found
Post by Wayne Sheldon » Mon Aug 24, 2020 3:35 am
Looking good W V !
John Warren
Last Name: Warren
Post by John Warren » Mon Aug 24, 2020 8:40 am
Great start, keep us posted. Thanks for sharing. jw
Will_Vanderburg
First Name: William
Post by Will_Vanderburg » Mon Aug 24, 2020 12:52 pm
I took the horn outside and hooked it up to my Touring. It WORKS....
