Radiator repair--Neck loose
rlcxz@yahoo.com
Last Name: Cook
* REQUIRED* Type and Year of Model Ts owned: 1922 1917
Post by rlcxz@yahoo.com » Sun Aug 23, 2020 9:47 pm
What should we use to repair a loose neck to the radiator? 1922 coupe. It looks like it has been fixed before.
Bob
Re: Radiator repair--Neck loose
Post by RajoRacer » Sun Aug 23, 2020 10:29 pm
Remove it and get it to a competent radiator shop that is familiar with antique autos for proper re-soldering.
Willie R
First Name: Willie
Last Name: Rathbone
* REQUIRED* Type and Year of Model Ts owned: 1921 Touring
Board Member Since: 2006
Post by Willie R » Sun Aug 23, 2020 10:34 pm
Save your time and money. Fix it like the old timers did. Keep your credit card in your wallet. Clean the mating surfaces with muratic acid and use flux, solder, and a propane torch to weld it back. Easy to do.
Last Name: Juhl
Post by Oldav8tor » Sun Aug 23, 2020 10:38 pm
When my radiator filler neck came off I took it to an old time radiator shop. He did a great job and it cost me only $20. I would have spent that much for the materials to do my own repairs and might have produced amateurish results.
Post by RajoRacer » Mon Aug 24, 2020 11:02 am
Apparently some other "hack" previously attempted an amateur soldering job, Willie !
