Battery charging from the magneto
Rjackson
First Name: Ron
Last Name: Jackson
* REQUIRED* Type and Year of Model Ts owned: 1915 roadster 1925 coupe 1923 Tudor 1927 speedster
Board Member Since: 2014
Post by Rjackson » Wed Aug 26, 2020 6:18 pm
They have had a charger that could be wired to your mag post to charge a 6 or 12 volt battery. No one has them any more. Does anybody know where to get one. I am looking for one that will charge a 12 battery. Thanks
Last Name: Strange
Re: Battery charging from the magneto
Post by CudaMan » Wed Aug 26, 2020 6:31 pm
If you can't find one ready made, you could make your own. :)
http://www.mtfca.com/discus/messages/41 ... 1416288062
Post by Steve Jelf » Wed Aug 26, 2020 11:29 pm
SurfCityGene
First Name: Gene
Last Name: Carrothers
Post by SurfCityGene » Thu Aug 27, 2020 12:44 am
Ron, Have you contacted John Regan. He recently just made up a perfect solution and location to mount it and had them available?
His latest design is the best of all and is most simple to connect to the bat and mag posts. Check it out
1912 Torpedo Roadster
Post by TRDxB2 » Thu Aug 27, 2020 12:22 pm
Post by Steve Jelf » Thu Aug 27, 2020 2:01 pm
Looks like I copied John, but without the green base. :D
Rjackson
First Name: Ron
Last Name: Jackson
Post by Rjackson » Thu Aug 27, 2020 2:45 pm
How would I find this John Regan do you have his phone number or email thanks, Ron
Post by Steve Jelf » Thu Aug 27, 2020 4:02 pm
Ron, go to Extra Quick Links at the top of this page and click on Find a Member.
Entering his first and last name should get you the contact info.
SurfCityGene
First Name: Gene
Post by SurfCityGene » Sat Aug 29, 2020 2:10 am
Ron, If you look back up to the picture of Johns charger there is a link to another discussion. If you go there and scroll down to the bottom you'll see a post from John. It's easiest to contact a p[oster when you simply click on their name and you can send them a note directly.
Rjackson
First Name: Ron
Last Name: Jackson
Post by Rjackson » Sun Aug 30, 2020 3:53 pm
Again I would like to thank all you guys for your help. I have found the charger I need thanks to John Regan
