Radiator Shell Lacing
cntbill
First Name: Bill
Last Name: Burkhardt
Post by cntbill » Wed Aug 26, 2020 10:19 pm
Put on new lacing on my radiator shell but not sure what to do with the two ends, do I just trim it close to the end and just let it hang or wrap it around ?
Thanks,
Bill...
End 1
End 1
End 2
End 2
End 3
End 3
jiminbartow
Last Name: Patrick
Re: Radiator Shell Lacing
Post by jiminbartow » Thu Aug 27, 2020 12:44 am
Trim ends even with the bottom of the shell flange. The purpose of the lacing is to prevent metal to metal contact and the noise that would occur from intense vibration. Jim Patrick
cntbill
First Name: Bill
Post by cntbill » Thu Aug 27, 2020 1:16 am
OK, then what about putting a spot of silicon on the very bottom to help keep the lacing in place?
Post by Allan » Thu Aug 27, 2020 2:05 am
Just cut it of an inch or so from the last hole. It won't go anywhere.
cntbill
First Name: Bill
Post by cntbill » Thu Aug 27, 2020 9:11 am
Ok, Thanks guys, that is what I'll do. I just wasn't sure what the proper method was.
Last Name: Hjortnaes
Post by DHort » Thu Aug 27, 2020 5:43 pm
The lacing is wax impregnated which made it stiff enough that I just bent the last 2 inches or so and stuck it between the shroud and the radiator. It isn't going anywhere.
cntbill
First Name: Bill
Post by cntbill » Thu Aug 27, 2020 8:14 pm
Makes sense, Nice headlamp !
Post by DHort » Thu Aug 27, 2020 9:06 pm
My car should be all black. A previous owner plated the headlights, shroud, and side lights. 1920 - wanted it to look like a brass car.
Adam
First Name: Adam
Last Name: Doleshal
Post by Adam » Fri Aug 28, 2020 10:42 am
I believe the original lacing wrapped around and tucked between the shroud and the lacing on the loop above it.
Post by DanTreace » Fri Aug 28, 2020 11:00 am
Ford Service photos of end of radiator shell lace, just trim the loose end short to hang just inside the shell behind the frame.
cntbill
First Name: Bill
Post by cntbill » Sat Aug 29, 2020 12:47 am
Wondering about that, but still looks neat....
Sounds like a plan....
Much better photos then the Ford Service book that I have....
Thanks guys! Solves my mystery...
