Flip top jack
First Name: Jeff
Last Name: Humble
Board Member Since: 2006
Flip top jack
Post by Humblej » Mon Feb 18, 2019 6:51 pm
Was at the Benson Ford Research Center today, found the jack drawings. The pressed steel jack changed to the flip top design in drawing dated August 1925. The part number remained the same. Applicability: "all T chassis".
Dropacent
Last Name: Morsher
Re: Flip top jack
Post by Dropacent » Mon Feb 18, 2019 7:45 pm
Thanks Jeff ! Do you remember if the flip part had a hole, or no hole on the side?
First Name: Jeff
Last Name: Humble
Re: Flip top jack
Post by Humblej » Mon Feb 18, 2019 7:56 pm
I do not remember seeing one there, but I didnt look for one either.
Dropacent
Last Name: Morsher
Re: Flip top jack
Post by Dropacent » Mon Feb 18, 2019 8:01 pm
Thanks , I just stole this from the model A site. They say the “no hole” is model T. It’s nice to know the date now !
Dropacent
Last Name: Morsher
Re: Flip top jack
Post by Dropacent » Mon Feb 18, 2019 8:03 pm
fliverfan
First Name: Bill
Last Name: Chuplis
Re: Flip top jack
Post by fliverfan » Tue Feb 19, 2019 9:34 am
With the suspension being lowered on the 26-27, the date, more or less speaks for itself. The non-flip type is a mystery to me. They look too short for use on a 25 and bit too tall for use on a 26-27.
Dropacent
Last Name: Morsher
Re: Flip top jack
Post by Dropacent » Tue Feb 19, 2019 9:41 am
Here are all that I know of. It would be nice to have aprox dates with them. The model A historians have pinned their jacks down to the month.
Re: Flip top jack
Post by DanTreace » Tue Feb 19, 2019 10:13 am
Info researched by Trent Boggess
On 9/10/24 the pressed steel jack design was adopted.
The car jack is 8-5/8” tall and the base is 4-1/2” across.
The handle was made a separate part and carried the
factory symbol number T-3391-B.
...the old style screw jacks were declared
obsolete on 9/13/24. It appears that the pressed steel
design were the standard issue jacks on the 1925 models.
About a year later on 8/4/25 the design of the jacks was
revised. On both the car and truck jacks a two-inch
extension was added to the top of the jack.
Old style screw jack compared to 1926 style flip top, compressed size on front axle, Improved Car
Old style screw jack compared to 1926 style flip top, extended size on rear axle, Improved Car.
Re: Flip top jack
Post by DanTreace » Tue Feb 19, 2019 10:20 am
And that flip top jack is well suited as the 'universal jack' as it can be used with the 'flip' folded over if the front tire is flat on the ground, either style of T's early or late. With the flip over......that jack is the lowest version to fit under the T front axle ;)
fliverfan
First Name: Bill
Last Name: Chuplis
Re: Flip top jack
Post by fliverfan » Tue Feb 19, 2019 11:44 am
The date for the hole addition in the flip top is probably buried somewhere the Walker Jack Co. files.
It doesn't seem to serve any Ford purpose so it's doubtful they made it a requirement.
J1MGOLDEN
Last Name: Golden
Re: Flip top jack
Post by J1MGOLDEN » Tue Feb 19, 2019 3:47 pm
While I learned some time ago that the hole was in the Model A jack, I have never been able to find a reason for that hole.
fliverfan
First Name: Bill
Last Name: Chuplis
Re: Flip top jack
Post by fliverfan » Tue Feb 19, 2019 4:29 pm
Never been able to find the reason they're (MAFCA) so sure the hole was never there prior to the 28 model year either.
D Stroud
First Name: David
Last Name: Stroud
Board Member Since: 2011
Re: Flip top jack
Post by D Stroud » Thu Feb 21, 2019 6:30 am
Bill C., the lower suspension on the later cars would have nothing to do with the jacks. Tire size would though. JMHO Dave
1925 mostly original coupe.
fliverfan
First Name: Bill
Last Name: Chuplis
Re: Flip top jack
Post by fliverfan » Thu Feb 21, 2019 11:03 am
So could raising the front spindles without changing the tire diameter.
From the encyclopedia:
"The “improved” Fords were lower in height than the previous models. This height reduction was accomplished by not only reducing the height of the bodies themselves (except for the Fordor) but also by lowering the frame by a redesign of the front spindles, and a reduction of the crown in the front spring."
