Venting rear diff
Dennis Prince
Last Name: Prince
Venting rear diff
Post by Dennis Prince » Tue Feb 19, 2019 12:22 pm
I am wondering if you need to add a vent to the rear axle tube when going to a modern pinion bearing setup, they say that one or more of the bearings are sealed and I am thinking that I need to add a vent. This could be a dangerous move but "what do you think?"
i
Re: Venting rear diff
Post by Scott_Conger » Tue Feb 19, 2019 12:40 pm
Not needed. Don't overthink it.
John M Maslack
Last Name: Maslack
Post by John M Maslack » Tue Feb 19, 2019 1:01 pm
I vented the Ruckstell I rebuilt for my speedster. With the sealed pinion and in my case, sealed safety hubs and neoprene grease seals, I feel the axle is pretty much air tight....
John M Maslack
Last Name: Maslack
Post by Scott_Conger » Tue Feb 19, 2019 1:08 pm
If venting an axle or torque tube makes someone sleep better at night, then there is some value in it, I suppose. However, with respect to pressure, there is nothing sealed about a sealed bearing. There is nothing in a Model T drive line that is building pressure that will not leak past a sealed bearing.
DHarrison
First Name: David
Last Name: Harrison
Post by DHarrison » Tue Feb 19, 2019 10:14 pm
I believe a Ruckstell has a small vent that comes out under the name plate.
Post by Mark Gregush » Wed Feb 20, 2019 12:51 am
Re; I believe a Ruckstell has a small vent that comes out under the name plate.
No it does not.
Post by Steve Jelf » Wed Feb 20, 2019 2:23 am
The carburetor has an air vent under the name plate. That's why you've never heard of anybody having trouble with their carburetor bearings.
Mindless Automaton
First Name: Kep
Last Name: Kerensky
* REQUIRED* Type and Year of Model Ts owned: 23 truck, 26 bug
Board Member Since: 2011
Post by Mindless Automaton » Wed Feb 20, 2019 2:33 am
I thought they were vented through the axle shafts? into the brake drums.
George Andreasen
Last Name: Andreasen
* REQUIRED* Type and Year of Model Ts owned: 0...building from parts
Post by George Andreasen » Wed Feb 20, 2019 6:10 am
Bwahahahaha! :lol: And all this time I thought that muffler bearings were the culprit..............
Alan Long
First Name: Alan
Last Name: Long
Post by Alan Long » Wed Feb 20, 2019 7:22 am
I believe this is a great question. The original Differential design has numerous areas where any expansion or built up
pressure can escape but when you move a few steps into modern design a vent would be desirable. I have the
Sealed Pinion unit, Safety Hubs plus leather seals inboard of the Safety Hubs and a coil “wind back” spring on the axle. I have gone to great lengths To prevent pesky oil leaks but suffer with oil leak from the LH Wheel (typical of driving on the LHS of the road) Modern vehicles have breathers and their sealing devices are similar in effectiveness to what I now have in my T.
I look forward to hearing other experiences that others have with breathers
Alan
John Warren
Last Name: Warren
Post by John Warren » Wed Feb 20, 2019 8:56 am
If the axle is sealed like a new axle, it should be vented. Could help keep grease/oil out of the brakes. Be sure and put a snorkel tube on it if your going to forge any rivers.:)
Post by Original Smith » Wed Feb 20, 2019 9:37 am
A Ruckstell housing has no vent under the Ruckstell plate. You must be thinking of a NH carburetor!
Ruxstel24
Last Name: Hanlon
Post by Ruxstel24 » Wed Feb 20, 2019 10:09 am
Venting is a good idea, but on a T it seems, even with modern sealers, etc. I can't imagine that pressure would not be vented through the torque tube and u-joint ball and/or the engine. :?:
Adam
First Name: Adam
Last Name: Doleshal
Post by Adam » Wed Feb 20, 2019 11:31 am
One of the biggest rough running issues that often goes undiagnosed is a loose carburetor bearing! (Where the throttle shaft passes thru the casting). It is an intake air leak at high vacuum condtions thus causing too rich a mixture at low vacuum and too lean a mixture at high vacuum.
Post by Steve Jelf » Wed Feb 20, 2019 12:17 pm
Quite true. Sometimes the hole is worn, sometimes the shaft, and sometimes both.
RustyFords
First Name: Don
Last Name: Allen
Post by RustyFords » Wed Feb 20, 2019 12:50 pm
Very true...even on carbs on much later model cars.
1924 Touring
George N Lake Ozark
First Name: George P
Last Name: Clipner
Post by George N Lake Ozark » Wed Feb 20, 2019 2:50 pm
I've seen many used rear axles with vents in the axle tube. Mine has a vent also. Some people worry about dirt getting in also, Mine has a flip top press in oiler in the dried hole.
rofirestone
First Name: Roy
Last Name: Stone
* REQUIRED* Type and Year of Model Ts owned: 1915 Touring--1925 Tudor
Post by rofirestone » Wed Feb 20, 2019 6:33 pm
I have the modern axle seals & immediately after a long drive I removed the diff: oil plug to check the oil level and heard a puff of air exit. That was enough for me to install a vent.
Mindless Automaton
First Name: Kep
Last Name: Kerensky
Post by Mindless Automaton » Thu Feb 21, 2019 12:49 am
What about putting a vacuum line into the vent to keep the oil from leaking out?
Don Conklin
First Name: Donald
Last Name: Conklin
* REQUIRED* Type and Year of Model Ts owned: 1919 touring, 1923 depot hack, 1927 speedster
Post by Don Conklin » Thu Feb 21, 2019 7:13 am
I had a similar experience as Roy Stone. I saw a small bubble as I was removing the plug. Drilled the plug and installed a vent line that runs up to the frame.
I also had thought of a vacum line when a rear axle seal started to leak but redoing the seal and lowering the fluid level has resolved that problem.
