timer problems
Mr man
First Name: Carson
Last Name: Combs
* REQUIRED* Type and Year of Model Ts owned: 1924 touring, 1923 roadster pickup project
timer problems
Post by Mr man » Fri Sep 11, 2020 11:46 pm
i took my timer off to clean, and when i put it back on, and all the wires, and tried to start it, it would not start and the carburetor started backfiring. any ideas? its a tiger timer.
thanks,
carson
Re: timer problems
Post by Steve Jelf » Sat Sep 12, 2020 12:05 am
My guess would be that you got a wire or two in the wrong place.
Be sure all wires are in the right place.
While you're at it, check the timing: http://dauntlessgeezer.com/DG97.html
MKossor
Last Name: Kossor
Re: timer problems
Post by MKossor » Wed Sep 16, 2020 2:33 pm
Did you remove the roller? Some CAM shafts are drilled all the way through allowing the roller to be installed 180 degrees off (i.e. Backwards)
Mr man
First Name: Carson
Last Name: Combs
Re: timer problems
Post by Mr man » Wed Sep 16, 2020 4:59 pm
yes, it turns out i had the roller backwards!
thanks for the help guys
