My 15 runabout has a steel hood.
Would the 15/16 steel hoods have these plates?
They don't seem to be needed.
I can see them on an aluminum hood because it is softer and could wear.
hood clip plate
Re: hood clip plate
? you are missing something.
JEC
Topic author - Posts: 132
- Last Name: Cox
- * REQUIRED* Type and Year of Model Ts owned: 1915 Runabout, 1925 Pickup
Re: hood clip plate
My hood is after market and doesn't have the plates.
I ordered them from Langs and have them.
They don't fit correctly at the bottom and I can't see why Henry would have used them.
Re: hood clip plate
What plates are you talking about? How about a link to Lang's item so some of us know what you are asking about. That is why I said you are missing something, thought maybe you forgot to add a photo of the part.
JEC
- Last Name: Cox
Re: hood clip plate
Link to Langs catalog page.
https://www.modeltford.com/item/4054PLS.aspx
Re: hood clip plate
Thank you. http://www.rootlieb.com/ford-model-t-hoods.html
Looks like some of the current repos aluminum hoods have them and some don't. I would not think that the steel 16 hood would need them as they would be no different then the later ones.
- Attachments
- 1511006s.jpg (3.69 KiB) Viewed 3953 times
JEC
- Last Name: Cox
Re: hood clip plate
Thanks Mark
I hadn't thought about looking at Rootliebs site.
