If you need help logging in, or have question about how something works, use the Support forum located here
Support Forum
jagiven
- First Name: Jason
- Last Name: Given
- * REQUIRED* Type and Year of Model Ts owned: 26 Roadster, 25/26 speeder
Post
by jagiven » Tue Feb 19, 2019 8:56 pm
Ran into an issue balancing the triple gears.
1st triple gear drilled out just fine.
2nd triple gear, the heaviest one, I center punched and drilled two pilot holes. No issue.
Stepped up to a larger bit, and the bit just chatters, and loses it edge, almost immediately. No matter what size or coating on the drill bit. Both holes. I used motor oil as a cutting lubricant.
I have sharpened those bits on my Drill Doctor about 12 times.
I have drilled a lot of holes in metal over the years and do not recall ever having this much issue.
Purely clueless and frustrated
Post
by Jerry VanOoteghem » Tue Feb 19, 2019 9:05 pm
Certain high carbon steels can do that, even if they're not exactly heat treated. The heat & work of drilling can cause the steel to harden. You'll most likely have to choose another spot to drill, since the spot you tried has now been work hardened. A very sharp drill will help. Maybe try a carbide tipped drill.
Post
by Scott_Conger » Tue Feb 19, 2019 9:17 pm
And such is the reason I balance flywheels with the triple-gears in place.
Les Schubert
- First Name: Les
- Last Name: Schubert
Post
by Les Schubert » Tue Feb 19, 2019 9:36 pm
Consider a carbide drill bit
jagiven
- First Name: Jason
- Last Name: Given
Post
by jagiven » Tue Feb 19, 2019 10:58 pm
Jerry VanOoteghem wrote: ↑Tue Feb 19, 2019 9:05 pm
Followed your suggestion and got them all balanced.
Adam
- First Name: Adam
- Last Name: Doleshal
Post
by Adam » Wed Feb 20, 2019 11:41 am
If you can drill into a triple gear with a regular drill bit, you should be suspicious that it isn’t properly heat treated and maybe use a different gear. The hardness of the triple gears is such that you should have to use a solid carbide drill, endmill, lathe bit, etc to remove material from them. They are not hard all the way thru, but are hard to a certain depth. I use a 3/8” solid carbide end mill to “drill” into them for balancing. Generally when I get maybe about .040” to .060” deep then they cut easier. That generally seems to be the depth of the heat treating.
Altair
- First Name: David
- Last Name: Menzies
- Board Member Since: 2012
Post
by Altair » Thu Feb 21, 2019 9:49 pm
Maybe you are running your drill too fast you didn't say that you slowed it down. The gears would be cut before hardening then the gear is heated red and quenched with oil to harden and it may not be consistently hard thought. Some gears may chip, wear or break they are not made to an exact science just general. Try advancing the drill size in smaller increments.
Post
by Allan » Sun Feb 24, 2019 7:24 am
The riveted 3 piece gears are more problematical to balance. Not all pieces are perfectly centred before the gears are cut. When the three components are put together there can be quite a variation in their weight. Off centre pieces can be a bonus when balancing the gears, as the off-centre part is the bit removed when machining them. Balancing these unbalanced gears on a flywheel assembly is less than satisfactory. The orbit in which they rotate and their own rotation on the pins will greatly affect the total balance. This is a problem of much lesser magnitude when using the totally machined one piece gears.
Hope this helps.
