Winfield S & SR carburetor parts **NEW**
Kevin Pharis
Topic author - Posts: 1656
- First Name: Kevin
- Last Name: Pharis
Brand new Winfield model S & SR carburetor choke horns, V band clamps, and choke brackets now available. All components are near exact reproductions of the original designs and will interchange with original components. Current available size is AA-B only. Other sizes to be available depending upon demand.
Choke horns are machined from solid aluminum and are ready to install. Completely assembled with new stainless steel choke butterfly and brass pivot shaft. $250 ea.
V band clamps are machined from solid stainless steel and are ready to install, complete with stainless steel hardware. $90 ea.
Choke brackets are stamped from stainless steel and are ready to install, complete with stainless steel mounting screws and clamp screw/nut. $40 ea.
- First Name: Henry
- Last Name: Lee
Re: Winfield S & SR carburetor parts **NEW**
Very nice work Kevin!
Kevin Pharis
- First Name: Kevin
- Last Name: Pharis
Kevin Pharis
- First Name: Kevin
- Last Name: Pharis
Kevin Pharis
- First Name: Kevin
- Last Name: Pharis
Been working on a new float bowl... pics coming soon
elliott1936
- First Name: Tom
- Last Name: Elliott
- * REQUIRED* Type and Year of Model Ts owned: 1921 Speedster 1927 speedster
- Board Member Since: 2013
Kevin:
I would like to purchase a clamp for the air horn. Tom Elliott 503-644-9374
Kevin Pharis
- First Name: Kevin
- Last Name: Pharis
Kevin Pharis
- First Name: Kevin
- Last Name: Pharis
Kevin Pharis
- First Name: Kevin
- Last Name: Pharis
Have been continuing toward my goal of building complete S-B downdrafts from scratch. So far the choke horn, V band clamp, and float bowl are done. The float bowl cover and float ball for both S and SR carbs are next.
dmdeaton
- First Name: Danny
- Last Name: Deaton
Wow!!!!!!!
Here is my old beater
John bevardos
- Last Name: bevardos
- * REQUIRED* Type and Year of Model Ts owned: Roadster, Coupe, pickup truck, 2-door
How well do these perform . I have a couple at home and haven't tried them .......yet .
John
John
Who's still makes these gaskets, I might be in the market for a solid copper one myself.
Kevin Pharis
- First Name: Kevin
- Last Name: Pharis
I’m a bit biased... so I will hold my commentsJohn bevardos wrote: ↑Fri Dec 04, 2020 12:50 pmHow well do these perform . I have a couple at home and haven't tried them .......yet
Kevin Pharis
- First Name: Kevin
- Last Name: Pharis
I’m still workin toward complete carbs, and so have straight and elbow choke horns, V band clamps, choke brackets, and now fuel inlet blocks in stock. Will also have S and SR float balls, and modern needle and seat float bowl covers available soon...
Susanne
- First Name: Susanne
- Last Name: Rohner
When you get it PLEASE let us know, I have a B sized BB body that is perfect but for the manifold flange on top that has a radial crack 60% around it...it makes me sick, as I want so bad to rin this carb, but I know, lest I build a brace to hold it up, it will fail...
What you are doing is a true GIFT to the hobby... I just wanted to say that... along with our heartfelt thanks!!!
Kevin Pharis
- First Name: Kevin
- Last Name: Pharis
Continuing to make progress, now have new float bowl covers complete with ball detents, new float levers, and Viton tipped float needles
And here’s a pic of progress so far, still have some cosmetic work to do to the exterior of the throttle barrel, but otherwise is internally finished
Kevin Pharis
- First Name: Kevin
- Last Name: Pharis
Guess it’s been a while since the last bump. Have been continually adding new parts and accessories for Model S and SR series carbs. All interchangeable with original components, from gaskets to throttle barrels.
V band clamps in all sizes Compensator and accelerator pump tools Brass floats
