What Should I Do With Them?
BLB27
First Name: Bruce
Last Name: Brakke
Post by BLB27 » Sat Sep 19, 2020 8:25 pm
I am disassembling my 27 coupe. I plan to reuse the various bolts and other fasteners (I assume that is the way to go!) I will soak them in " Krud Kutter - Must for Rust". Any comments or suggestions?
I put them in plastic bags and mark what part they came from.
Jonah D'Avella
First Name: Jonah
Last Name: D'Avella
Re: What Should I Do With Them?
Post by Jonah D'Avella » Sat Sep 19, 2020 8:55 pm
I zip tie index cards to bags with the parts in baggies or tie them to the parts them selves.
F: first F: find
O: on O: oil
R: race R: revive
D: day D: drive
Jonahdavella@gmail.com
Chris Haynes
First Name: Chris
Last Name: Haynes
Post by Chris Haynes » Sat Sep 19, 2020 10:58 pm
I would strip them and re Parkerize everything. It is easy to do yourself.
Post by Steve Jelf » Sun Sep 20, 2020 1:12 am
Yes, original hardware is best. A lot of modern stuff doesn't match.
When you bag up and label things, keep them all in the same place so you can find them later.
You can't take too many pictures of how things go together.
If I have to use any modern bolts I grind and buff off the markings, strip off the cad plating (paint won't stick to it) with muriatic acid, prep, and paint. I prefer satin black Rustoleum for chassis parts and hardware.
BLB27
First Name: Bruce
Last Name: Brakke
Post by BLB27 » Sun Sep 20, 2020 1:40 pm
What is Parkersize?
Post by TRDxB2 » Sun Sep 20, 2020 2:29 pm
What is Parkersize?
Parkerizing is a method of protecting a steel surface from corrosion and increasing its resistance to wear through the application of a chemical phosphate conversion coating.
Krud Kutter Must for Rust "Is a phosphoric acid based formulation that dissolves rust/oxidation through chemical action. Then tiny, rust-inhibiting crystals are formed and become integral with the surface molecules of the metal to resist future rusting. The corrosive agents attack these crystals instead of the metal. Once completely dry, the surface is ready for the next step, whether it be painting, welding, plating, lubricating, etc. Or simply leave the surface bare, and the crystals will inhibit future rust formation."
