By request, My '23 Gow Job build pics (speedster)
Chad_Marcheese
First Name: Chad
Last Name: Marcheese
* REQUIRED* Type and Year of Model Ts owned: 1925 Cut Off Touring / Pickup, 1923 Speedster Gow Job
Post by Chad_Marcheese » Sun Sep 20, 2020 11:09 am
I prefer to use the early term Gow Job, rather than speedster. To me, a Gow is a modified full body car where a speedster tends to have a smaller (or none) homemade body, and sometimes a single seat car.
In another thread, some requested me to post pics. So here goes. Started about three years ago. I am still a long ways away, but its coming around. Shape eye people might have seen a brief write up earlier this year in Hemmings.
The goal is to use only aesthetic parts available from 1935 or older. There will be some more modern parts (specifically in the engine / drivetrain area that will be much newer, but hopefully none of those grow to become viewable out in the open. I am trying to make an as correct pre-war car as I can.
Please let me know if you have any questions, I will list the current state of parts.
'23 Roadster body
'20's frame
T block with A crank and rods, custom pistons
Frontenac "T" model head
SU - HS6 carb
Laural-Roof cam
Semi- pressured oiling
Model A front end and steering
Model A wire wheels (19's will be the final size)
Lowered 5"
Model A trans
T rear axle
Speedster Project 15.1.jpg (109.43 KiB) Viewed 9938 times
Speedster Project 25.1.jpg (91.32 KiB) Viewed 9938 times
Speedster project 59.jpg (99.43 KiB) Viewed 9938 times
Last edited by Chad_Marcheese on Sun Sep 20, 2020 11:27 am, edited 1 time in total.
Chad_Marcheese
First Name: Chad
Re: By request, My '23 Gow Job build pics (speedster)
Post by Chad_Marcheese » Sun Sep 20, 2020 11:12 am
Speedster project 129.1.jpg (81.96 KiB) Viewed 9935 times
Chad_Marcheese
First Name: Chad
Post by Chad_Marcheese » Sun Sep 20, 2020 11:15 am
Chad_Marcheese
First Name: Chad
Post by Chad_Marcheese » Sun Sep 20, 2020 11:18 am
Speedster project 186.1.jpg (95.46 KiB) Viewed 9928 times
Chad_Marcheese
First Name: Chad
Post by Chad_Marcheese » Sun Sep 20, 2020 11:21 am
Speedster project 202.1.jpg (93.77 KiB) Viewed 9927 times
Speedster project 206.1.jpg (57.69 KiB) Viewed 9927 times
Speedster project 208.jpg (68.97 KiB) Viewed 9927 times
Speedster project 210.1.jpg (76.92 KiB) Viewed 9927 times
Chad_Marcheese
First Name: Chad
Post by Chad_Marcheese » Sun Sep 20, 2020 11:22 am
Speedster project 214.1.jpg (55.63 KiB) Viewed 9926 times
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Sun Sep 20, 2020 11:35 am
Some serious progress Chad.., Looking Good!
Chad_Marcheese
First Name: Chad
Post by Chad_Marcheese » Sun Sep 20, 2020 12:06 pm
Thanks Hank, your one of the big parts in this also.
A week off home on vacation, even with a messed up back, I made substantial progress this week alone.
Post by Allan » Sun Sep 20, 2020 7:52 pm
Chad, there are much earlier versions of the S U carburetor which would be closer to your aim of using pre 1935 parts. They work in the same way, but are constructed differently, with some brass components. The larger sizes are a little more difficult to come by. Based on the type of air cleaner on your example I would guess it is early 60's. The first Mini Coopers had two such air cleaners. In Australia these were totally inadequate, and were soon replaced with paper element filters enclosed in a single box.
My son has a really early brass bodied SU to use on a speedster he may build, perhaps, one day, when he gets the time!
Chad_Marcheese
First Name: Chad
Post by Chad_Marcheese » Sun Sep 20, 2020 8:54 pm
Allan, you are totally correct on the carb, it is in fact an early 60's carb. There are a few exceptions I will be making as I have mentioned, however this is one that if you know (most won't), it can stick out a little. And for my budget, this SU fits the needs and looks.
Astute people like yourself that know these will say close enough as the design and looks didn't vary to greatly over the very long production run. Thus why I chose the SU as it could have been had way back when in the time period, just not this exact design / model, and these came at a fair price when they came up for sale.
Are you saying the air cleaner was inadequate because of air flow or filtering capability? They have a cool look to them that I feel I can skate by on the time period.
Last edited by Chad_Marcheese on Sun Sep 20, 2020 10:07 pm, edited 1 time in total.
dobro1956
First Name: Donnie
Last Name: Brown
Post by dobro1956 » Sun Sep 20, 2020 9:12 pm
Chad, You have been busy. Glad to see you posting again .... Looks good...
Chad_Marcheese
First Name: Chad
Post by Chad_Marcheese » Sun Sep 20, 2020 10:11 pm
Thank You Donnie. Feels good to post some. I have and have not been busy depends on the day, and sometimes the hour. While still younger than some here, I have ambition issues....or may be it's time issues...money issues? Yeah, something like that LOL. :lol:
Duey_C
First Name: Duane
Last Name: Cooley
Post by Duey_C » Mon Sep 21, 2020 1:58 am
I'm so glad you posted your GOW-job here too! Yeehaw!
Summer sure dragged me down! ;) I hear ya loud and clear.
Or am I waiting for the OT project to "go to town" here...
Itchin' for more Chad. :)
Post by Allan » Mon Sep 21, 2020 4:56 am
Chad, those filters were good at keeping birds out, but not much good for dust. I guess dust is not such an issue in England, the home of the Mini's, but it sure is out here. They were small and fitted directly onto the carb, so that made it easy in the confined engine bay on a Mini. The box/paper element replacement necessitated a pair of cast alloy elbows to lift the assembly up onto level and into a larger space.
Different SU carbs of 1.25" up to 2" were used on all sorts of engines with widely differing capacities and number of cylinders. With a huge range of jet tubes and needles, they could be tuned to almost anything.
Chad_Marcheese
First Name: Chad
Post by Chad_Marcheese » Mon Sep 21, 2020 6:24 am
Thank You for the response Allan, I appreciate it.
Yes, not much dust here either. So I am not overly worried about it....however I did have thoughts of making a setup for a real air filter just for such occasions.
A friend of mine had to sell me on the SU, they do have some great benefits and as you said easily adaptable. Pretty simple carb actually. The Fronty has only one intake port, so I wanted to ram as much as I could through there, a good match for CFM seemed to be an HS-6 carb which has a 1-3/4" throttle bore. It might be a little lazy down low, but should scream mid to upper RPM's.
Chad_Marcheese
First Name: Chad
Post by Chad_Marcheese » Mon Sep 21, 2020 5:21 pm
Duey, Thank You. I'm itchin' for more to, I just don't know how fast I can get it done. I have some walls in the project I need to get broken down and done. Sometimes it's just a matter of time, sometimes money, and sometimes It's just a matter of how I want to accomplish them and set forth in doing so.
Waiting patiently for the engine work to have the A-crank and cam/lifters installed, that's going to be a hefty bill. Then it needs to be freighted back to me. Then once it comes back, I need to have the bores opened up for my pistons, and then the rotating assy balanced. Some of the bottom end work was to specialized for my guy to do, and he doesn't pour babbitt. After all that, I can final build the short-block. Then scheme up my oiling system, in the mean time I need to make an oil pan for the A crank. The one shown above is for a stock T crank. So many little things to do.
Tim Williams
Last Name: Williams
* REQUIRED* Type and Year of Model Ts owned: 1925 Model T Speedster, 1922 Model t Speedster project
Post by Tim Williams » Mon Sep 21, 2020 9:22 pm
Chad,
What is your engine builder charging(roughly) to do the A crank and Cam? Trying to determine if I want to go that route.
Tim
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Mon Sep 21, 2020 9:29 pm
Chad I have bolt on dimple bars if you need to borrow them for the A crank throws. Pretty simple, just heat the areas and hammer down where the voids are.
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Mon Sep 21, 2020 10:18 pm
Dang Hank...! Did you have a B crank in that thing?
Here is the last A crank I did...
I made a block to clamp to the pan, a special hammer to get down in there, and like you said... heat er up and hammer it down! Seems to me it was 3/16” offset in the side wall...🤔. Oh yeah... the 12 point aircraft nuts make a huge difference too😉
Chad_Marcheese
First Name: Chad
Post by Chad_Marcheese » Mon Sep 21, 2020 10:27 pm
Chad,
Tim
I'll just say between 1-2k (don't want to pin anyone down), Shipping was $325 there. I supplied all the parts, Cam, bearing cores, stock A crank that was cleaned and mag'ed, bake and blasted block, A rod cores for rebabbiting, Stipe adjustable cam gear, DMC crank gear, DMC billet main caps and bolts. There is alot of crank work that needs to be done as well as block mods, and then pouring all new babbit.
If I had the extra cash, I would have done the Scat crank as it is already machined to fit. I can (and am) getting two stock A cranks done for 1/2 of a Scat crank. Your mileage may vary.
It has some seriously decent parts in this thing.
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Mon Sep 21, 2020 10:27 pm
Special rods had some beef on them Kevin! I have clearance! LOL!
Duey_C
First Name: Duane
Last Name: Cooley
Post by Duey_C » Tue Sep 22, 2020 12:18 am
"So many little things to do." Right there with ya Chad! :)
Picked up a large brass/bronze cam gear-thrust ring for a single cam, 413, 4 cylinder (OT) I'm dumping $$$ into.
Thank goodness that was done by complete chance, stopping in today.
Ached for it (months) for some more weeks of work/fitting the other associated pieces together. Ahhh...
"...how fast I can get it done" Bah, it will take as long as it takes. ;)
Chad_Marcheese
First Name: Chad
Post by Chad_Marcheese » Tue Sep 22, 2020 6:07 am
Hey Hank,
For the A crank, I'm going to build a Fronty style pan so no worries on the clearance. I am not sure who's this is, but this is what I'll be trying to build.....That's the plan anyhow.
Nice work BTW, I am guessing that is set up for full pressure to rods and mains?
@Kevin Pharis , always nice work from you also. I wish I lived closer to people like you two...I could learn a thing or two.
Kevin, I assume ARP nuts? Thats a good tip, I'll look into getting some. I bought thier studs and thick-ish looking 6-point nuts for the cylinder head.
Dan McEachern
First Name: DAN
Last Name: MCEACHERN
Post by Dan McEachern » Tue Sep 22, 2020 12:34 pm
Regarding pan dimples- a little trick that seems to help with pan distortion- cut a slit in the side wall just under the thickness of the pan rail at the top of the dimple. I use a small cutoff wheel in a die grinder. Then dimple the side wall and weld the slit closed and grind smooth. This allows the side wall to move out without deforming the gasket surface as much.
Tim Williams
Last Name: Williams
Post by Tim Williams » Tue Sep 22, 2020 1:13 pm
Thanks Chad,
loving your project so far. Thankyou for the information on rough cost.
Tim
BlackTinLizzie
First Name: William
Last Name: Weiss
Post by BlackTinLizzie » Wed Sep 23, 2020 3:46 pm
Chad
This project is neat in so many ways.
Thanks for the update.
Bill
RustyFords
First Name: Don
Last Name: Allen
Post by RustyFords » Wed Sep 23, 2020 5:05 pm
I love it Chad.
A friend of mine is about to give me all the running gear out of his 31 Model A pickup and I'm looking for general ideas for a period gow job. Yours is giving me some great ideas.
1924 Touring
2nighthawks
First Name: Harold
Last Name: Schwendeman
Post by 2nighthawks » Wed Sep 23, 2020 8:39 pm
Very interesting thread and some great pictures of some very nice work. Just wondering Chad,...the one photo of the front end that shows other than Model A king pins. Is that a Model A front end with later Ford front end brakes, spindles, king pins, etc, etc? Just wondering,.....harold
2nighthawks
First Name: Harold
Post by 2nighthawks » Wed Sep 23, 2020 8:40 pm
2nighthawks
First Name: Harold
Post by 2nighthawks » Wed Sep 23, 2020 8:46 pm
Sorry about the "double post"! Computer very slow to post and fooled me,....didt'n think it posted the first time!
Chad_Marcheese
First Name: Chad
Post by Chad_Marcheese » Thu Sep 24, 2020 8:46 pm
Harold, It is just later style king pins. I have a new set of stock style "A" ones to go on. The entire front axle hub to hub is all "A", just no brakes on it. I wanted the better later steering over the T, that's really the only reason it's there. Plus I "think" the stock "A" axle is an inch lower than a T axle.
Chad_Marcheese
First Name: Chad
Post by Chad_Marcheese » Wed Dec 09, 2020 7:13 pm
just before the cold really set in, i mounted up a body side to see how all of this was coming together.
tman1913
Last Name: Bender
* REQUIRED* Type and Year of Model Ts owned: 1913 Canadian touring, 1924 Roadster, 1926 Mercury speedster, 1927 Roadster p/u, 1920’s bobtail dirt track racer
Post by tman1913 » Wed Dec 09, 2020 8:43 pm
Chad. Very nice. Looking forward to see pictures of the pan build
Chad_Marcheese
First Name: Chad
Post by Chad_Marcheese » Wed Dec 09, 2020 9:07 pm
Thanks Mike. But as engine guys, you and I know both know its whats under the hood that matters the most.
henryford2
First Name: Joseph
Last Name: Andulics
Post by henryford2 » Wed Dec 09, 2020 9:18 pm
What piston are you using with the A crank and rods?
Chad_Marcheese
First Name: Chad
Post by Chad_Marcheese » Wed Dec 09, 2020 10:09 pm
I posted this above, But these are custom Ross Pistons for use with the Fronty head.
Speedster project 206.1.jpg (57.69 KiB) Viewed 8569 times
henryford2
First Name: Joseph
Last Name: Andulics
Post by henryford2 » Wed Dec 09, 2020 10:19 pm
Thanks, for some odd reason I scrolled right past the first picture. Nice looking project, have fun. Joe
Chad_Marcheese
First Name: Chad
Post by Chad_Marcheese » Fri Dec 11, 2020 7:45 pm
Got my Christmas present today:
