Model TT Rear Leaf Springs ... How many Leaves?
StevenS
First Name: Steven
Last Name: Sebaugh
* REQUIRED* Type and Year of Model Ts owned: 1924 Touring, 1924 TT Truck
Post by StevenS » Mon Oct 05, 2020 10:58 pm
How many leaves are there in a Model TT rear leaf spring set up? The truck I have, has nine on each side. That seems like too much, because the leaves are very tightly compacted together under the cross member and there is no movement what so ever where they attach to the cross member. The leaves have been oiled and are not rusted together.
1924 Model T Touring
1924 Model TT Truck
1928 Graham-Paige model 619
1930 Model A Phaeton
HPetrino
First Name: Henry
Last Name: Petrino
Re: Model TT Rear Leaf Springs ... How many Leaves?
Post by HPetrino » Mon Oct 05, 2020 11:21 pm
You have the correct number of leaves. Nine on each side is what Ford put in the TT's. No two should be the same length. The top one is very short. The bottom one goes from the anchor bolt to the hanger assembly at the perch. Somewhere in the middle there should be a spring clamp.
Yes, they are very stiff. They don't give very much until you put a pretty heavy load on the truck. It'll ride rough when empty.
richc
First Name: Rich
Last Name: Chillingworth
* REQUIRED* Type and Year of Model Ts owned: 1924 C-Cab TT
Post by richc » Thu Oct 08, 2020 10:23 am
From the parts catalog...
Rear Springs.jpg (28.11 KiB) Viewed 1922 times
Although the top leaf is very short, they are often found broken.
Rich C.
HPetrino
First Name: Henry
Last Name: Petrino
Post by HPetrino » Thu Oct 08, 2020 12:47 pm
Rich,
When I took mine apart one of the little top leaves was broken and the other was missing altogether. I don't see how there can be much flex at the top of the stack. It's hard (at least hard for me) to understand why they are so commonly found broken.
Burger in Spokane
First Name: Brent
Last Name: Burger
Board Member Since: 2014
Post by Burger in Spokane » Thu Oct 08, 2020 11:06 pm
I tested my springs this week with a pallet of concrete, rebar, and some forming
lumber. Forty-two 80lb. sacks pencils out at 3360lbs. I discovered why Ruckstell
low was an option, when I hit a few of the hills ! :lol:
