Hi,
I received my headligths from Ross Benedict and they look great.
During assembly of the burner, I am in doubt what is the correct position of the "Y":
I believe "A" is the right?
Position of burner
dykker5502
Topic author - Posts: 504
- First Name: Michael
- Last Name: Deichmann
Position of burner
Ford Model T 1914 Touring
- First Name: Keith
- Last Name: Townsend
Re: Position of burner
Image A. Front to back.
You should not see the Y from the front.
Darin Hull
- First Name: Darin
- Last Name: Hull
- * REQUIRED* Type and Year of Model Ts owned: 1913 Model T & 1926 Model T project
- Board Member Since: 2010
Isn’t the point of the “A” configuration to cause the gas streams, when they hit each other, to create a wide/broad flame for greater reflected illumination?
Darin
Darin
Drkbp
- First Name: Kenneth
- Last Name: Parker
To help line up the burner,
I use a dab of pipe dope on the threads of the burner base
to keep the acetylene from leaking around base of the burner.
I like my burners "snug" on the base but not so tight I can't reach
in there with my fingers and line up the flame when lit.
I have a burner that makes a great flame but is crooked relative to the Mangin.
Slight twist of the burner lines the flame up and it stays put.
- Attachments
- HARVEYS DOPE.jpg (53.21 KiB) Viewed 2197 times
Adam
- First Name: Adam
- Last Name: Doleshal
“A” is correct for getting the most light and is the way they were originally aligned. However, with whatever is in there in place of a reflector, it is doubtful that the headlamps will produce enough light to drive by no matter what you do.
Terry_007
- First Name: Terry
- Last Name: Bond
- * REQUIRED* Type and Year of Model Ts owned: 1914 Touring, 1915 Chassis
Thought this diagram might be of interest.
- Attachments
- Headlamp burner diagram.jpg (43.05 KiB) Viewed 2118 times
dykker5502
That diagram was nice!
Thank you all.
Thank you all.
