Steel spoke wheel with ford logo ?
JW21TT
Topic author - Posts: 78
- First Name: Jim
- Last Name: Williams
- * REQUIRED* Type and Year of Model Ts owned: 1921 TT Wrecker 1920 TT Tanker
- Board Member Since: 2012
Looked all over for a name assuming that is aftermarket and I found a ford logo on the inner hub and a K in. The casting
No idea of the origin of this can someone enlighten me .
Thanks in advance
Jim
Thanks in advance
Jim
- Attachments
- image.jpeg (37.54 KiB) Viewed 2199 times
- image.jpeg (43.17 KiB) Viewed 2199 times
- image.jpeg (42.12 KiB) Viewed 2199 times
Re: Steel spoke wheel with ford logo ?
If it is a steel spoked wheel, I don't think they came with hubs, so your old hub would have been used.
- Last Name: Hatch
I think Dayton made some.
Someone that was at Luray looking for them. Me thinks. Dan
Chris Instness
- First Name: Christopher
- Last Name: Instness
- * REQUIRED* Type and Year of Model Ts owned: 1915 runabout, T speedster
I believe it is made by Kelsey. If you look on the inside of the felloe it may be stamped Kelsey Wheel Company.
tom_strickling
- First Name: Tom
- Last Name: Strickling
- * REQUIRED* Type and Year of Model Ts owned: 11 Torpedo, 18 Touring, 21 TT Huckster, 24 Roadster,snowmobile, Shaw tractor conversion
Th guy at Luray was looking for a 6 spoke steel wheel I think.
“The trouble with retirement is that you never get a day off.” – Abe Lemons.
Steel spoke versions, aftermarket, most all used std. Ford hubs.
