What year are these parts ?
Jim Sims
First Name: Jim
Last Name: Sims
* REQUIRED* Type and Year of Model Ts owned: 17 touring 20 roadster 21coupe 25tudor 25 pickup 27 coupe
Post by Jim Sims » Fri Oct 16, 2020 12:13 pm
Just picked up these roadster parts and would like to know the year before I try to sell them. The side panels are reproductions that still need work. Was panels without the flange for the tack strip ever used between 15 to 18?
wood
wood
side panel
side panel
side panel 2
side panel 2
Re: What year are these parts ?
Post by John kuehn » Fri Oct 16, 2020 1:08 pm
I’m not sure if the blue panels go with the other panels. The two red or primer quarter panels may not be for Ford 15-22 Roadsters. BUT I may be wrong. I have a 1919 Roadster that doesn’t have the lower turn at the top where the quarter panel attaches to the front panel.
Others more knowledgeable than me might know more.
Jim Sims
First Name: Jim
Last Name: Sims
Post by Jim Sims » Fri Oct 16, 2020 1:56 pm
John,the curved down part has actually been cut off for some reason. they should come out straight I compared these panels with my 20 roadster and they are the same.
