Wishbone Ball Cap Stud Sizes?
Rick_Benjamin
First Name: Rick
Last Name: Benjamin
* REQUIRED* Type and Year of Model Ts owned: 1923 Touring car, 1918 huckster
Post by Rick_Benjamin » Sun Oct 18, 2020 3:23 pm
Greetings Friends:
Can anyone tell me the bolt size / thread sizes of the "wishbone" ball cap bolt (stud)? I can't find this info searching here, or the web, or my various manuals and catalogs. I've attached a picture from one of the vendors just to be clear about the part I'm referring to.
I'm particularly interested in knowing the thread specs for the course end that screws into the ball cap socket on the oil pan.
I'm asking because I want to clean up the threads on one side of the ball cap socket, and before I put a tap in there I want to really know the correct size. I know how important those studs are for safety. Keeping that radius rod ball in place is critical.
Many thinks for the information.
Sincerely,
Rick Benjamin
Lewisburg, PA
Model T radius rod ball cap mounting bolt.jpg (19.25 KiB) Viewed 1784 times
R.V.Anderson
First Name: R.V.
Last Name: Anderson
Re: Wishbone Ball Cap Stud Sizes?
Post by R.V.Anderson » Sun Oct 18, 2020 3:30 pm
3/8 x 16 on the socket end; 3/8 x 24 on the nut end.
Rick_Benjamin
First Name: Rick
Last Name: Benjamin
Post by Rick_Benjamin » Sun Oct 18, 2020 3:34 pm
Thanks R.V. !
Now I can head back out to the barn and work on this.
Again, thanks!
Sincerely,
Rick B.
elliott1936
Last Name: Elliott
Post by elliott1936 » Tue Oct 20, 2020 1:04 pm
If anyone is in need of these studs, I have a coffee can full. Let me know if you want a set. Tom 503-644-9374
