Wiring Harness Question
TrashMan
First Name: Chuck
Last Name: Griffin
Post by TrashMan » Tue Oct 20, 2020 5:20 pm
I was working on my 25 T sedan not paying attention to my work light when my wiring harness and cutout started smoking. I pulled the wire off of the cutout it stopped. My work light has a magnet on the back, it must have stuck onto the cutout and closed the points, turning my generator into a toaster. My question is what gauge wire is acceptable to use to replace the burnt wires? Also, would I be correct in assuming my generator is toast?
First Name: Jeff
Last Name: Humble
Board Member Since: 2006
Re: Wiring Harness Question
Post by Humblej » Tue Oct 20, 2020 6:35 pm
12 gage wire, can't answer the generator question. You should add an in line fuse near the starter switch to your power wire. If you had enough power draw to melt the wire it would have blown the fuse, may or may not have protected your generator.
Last Name: Strange
Post by CudaMan » Tue Oct 20, 2020 7:17 pm
"Best" wiring diagram for a later starter equipped car, showing where to put the fuse:
