Mag verses battery
Divcoone
Last Name: Giles
* REQUIRED* Type and Year of Model Ts owned: Speedster
Mag verses battery
Post by Divcoone » Wed Oct 21, 2020 11:21 am
Simple question.
How does a model T ignition work on mag AC and battery DC?
Chris Barker
First Name: Chris
Last Name: Barker
Re: Mag verses battery
Post by Chris Barker » Wed Oct 21, 2020 12:02 pm
If you feed a trembler coil with DC it will fire and spark about 200 times per second until the tar melts.
The mag generates a series of voltage pulses - a positive pulse is followed by a negative pulse. There 8 cycles (16 pulses) per crank rev. Each pulse lasts long enough, and is strong enough to charge up the coil to the point that it fires at least once. It doesn't mind whether the pulse is +ve or -ve.
The timer switches each coil to the appropriate pulse for that cylinder
jab35
Last Name: Bartsch
Post by jab35 » Wed Oct 21, 2020 12:06 pm
Post by TRDxB2 » Wed Oct 21, 2020 12:07 pm
Everything you wanted to know about the ignitions system and wish you didn't ask
There are two things to consider
Coils https://en.wikipedia.org/wiki/Trembler_coil
"The trembler coil operates equally well from AC or DC electricity. In the Model T, a battery was used for starting, but once the engine started the supply was switched to the engine's own generator. The Model T was unusual in being fitted with an AC alternator (a permanent magnet magneto) rather than a DC dynamo. In these early days, this was not rectified and so the alternator's output remained as AC. This was entirely adequate to operate the ignition system, and after 1915 to power electric headlights, although it could not be used for battery charging."
There are Magneto Bulbs vs Non- magneto bulbs
The Model T ignition system https://www.modeltcentral.com/Model-T-F ... ml#Magneto points to other articles worth reading https://www.fordmodelt.net/downloads/Mo ... nition.pdf
Highly technical stuff
AC vs DC running
DC ignition http://www.antiqueautoranch.com/montana ... nition.htm
Mag ignition http://www.antiqueautoranch.com/montana ... ition2.pdf
Post by TRDxB2 » Wed Oct 21, 2020 12:11 pm
This is a pretty good article: http://www.funprojects.com/pdf/The%20Mo ... rt%201.pdf
Thanks for adding that!!!
Divcoone
Last Name: Giles
Post by Divcoone » Wed Oct 21, 2020 12:59 pm
Thanks for all the information.
Darin Hull
First Name: Darin
Last Name: Hull
* REQUIRED* Type and Year of Model Ts owned: 1913 Model T & 1926 Model T project
Board Member Since: 2010
Post by Darin Hull » Wed Oct 21, 2020 4:48 pm
James,
Good article from fun projects. Thank you for sharing.
Darin
MKossor
Last Name: Kossor
Post by MKossor » Wed Oct 21, 2020 11:22 pm
Here is measured performance data I took for three ignition operating conditions: 6V Battery, 12V Battery and Magneto using a New Day Timer and professionally adjusted coils.
Ignition operating on 12V battery was equivalent to Magneto operation when spark advance is properly controlled manually. 6V battery operation is notably degraded due to the longer coil dwell time to fire spark which reduces the available timing advance range. Some folks have reported minimal degradation with the spark advance range optimized for greater adjustment range.
