Check this out
Will_Vanderburg
First Name: William
Last Name: Vanderburg
Check this out
Post by Will_Vanderburg » Tue Nov 03, 2020 3:31 pm
One I got from an acquaintance of mine.
The other I got at Hershey last year.
William L Vanderburg
1922 Center Door Sedan
Fire_chief
First Name: Charlie
Last Name: Gagel
Re: Check this out
Post by Fire_chief » Tue Nov 03, 2020 4:18 pm
The top one is "T" screwdriver. The bottom one is not.
Will_Vanderburg
First Name: William
Re: Check this out
Post by Will_Vanderburg » Tue Nov 03, 2020 4:41 pm
Yes I know. They are similar, however
Peter, Memphis TN
First Name: Peter
Last Name: Claverie
Re: Check this out
Post by Peter, Memphis TN » Tue Nov 03, 2020 4:47 pm
The bottom one came with Evinrude and Johnson outboard motors (same thing - different paint)
Joe Bell
First Name: Joe
Last Name: Bell
Re: Check this out
Post by Joe Bell » Tue Nov 03, 2020 4:56 pm
That one looks like the one I hauled to hershey last year for a friend to find a new home.
Re: Check this out
Post by Steve Jelf » Tue Nov 03, 2020 5:44 pm
Compared to other Ford tools, those T screwdrivers are hard to come by. The wood handles don't have a great survival rate.
Will_Vanderburg
First Name: William
Re: Check this out
Post by Will_Vanderburg » Tue Nov 03, 2020 6:43 pm
I got it from a HUGE vendor of tools in the area before you cross the overhead walkway.
Last Name: Wrenn
Re: Check this out
Post by TWrenn » Wed Nov 04, 2020 10:06 am
Well, they may be scarce, but I have two of 'em! Took a while, but I found 'em. One is in slightly better cosmetic condition than the other, but both are decent anyway.
Re: Check this out
Post by Steve Jelf » Wed Nov 04, 2020 10:12 am
I know the one you mean, and HUGE is the right word. But I bet he doesn't have a lot of T screwdrivers.
Re: Check this out
Post by John kuehn » Wed Nov 04, 2020 10:30 am
The Ford screwdriver I had was used as a chisel in its latter days. So much for the wooden handle.
jab35
Last Name: Bartsch
Re: Check this out
Post by jab35 » Wed Nov 04, 2020 10:44 pm
Does the T screwdriver have a steel hex cap set into the end of the wood handle? The driver I have looks like the T driver in the pic, has a wood handle with steel hex end and it's a solid part of the square driver shaft. This seems to be a good feature for sensing the spark voltage when using the screwdriver to seek out faulty plugs on a running engine. jb
Re: Check this out
Post by Mark Gregush » Thu Nov 05, 2020 1:09 am
I wonder how many times my hands have gone up the screwdriver went flying! LOL Most the wood handle screwdrivers I have don't have the exposed shaft on the ends and of course the plastic ones don't ether so I don't ever think about it when I pick one up. Generally they get me when I use someone else's. :lol:
Re: Check this out
Post by Allan » Sat Nov 07, 2020 2:19 am
The A model equivalent has a round shaft which also goes clear through the handle. I found one like that with a Ford script on the shaft. I didn't know that when i bought it, as it had been used as a paint stirer.
I still use modern plastic handled drivers with steel clear through the handle. These are good to hammer on when trying to unscrew wood screws which have rusted in place.
Will_Vanderburg
First Name: William
Re: Check this out
Post by Will_Vanderburg » Sat Nov 07, 2020 6:43 pm
The shank of the screw driver (T one) goes all the way to the end of the wooden handle and is exposed
