Distributor
mrsummers
Distributor
I have a 1921 Touring Ford Model T, the old owner put a distributor on it and I'm not sure how to set the timing on the distributor and if anyone has instructions on how to set this you can email me with the possible instructions at deansummers52@yahoo.com,but eventually I will go back to the vibrating coils. Thank you Dean Summers
Re: Distributor
You need to ask your question on the general forum. This section is for issues with the site and not car questions. Please don't post your email in the post (click on the pencil to edit and remove it), easy for scammers to find. People can send via a PM and don't expect people to not reply on the forum, you need to check there too. While most setup the same, it would help to know which one you have, so post that info too. There is more then one brand of clip on distributor. The way you are signed up now, your information is not complete so can't send via a PM or email thru the system. Might want to update that.
