tractor conversion
Gene
First Name: Condon
Last Name: Story
* REQUIRED* Type and Year of Model Ts owned: 1911 torpedo 1916 tractor conversion 1922 roadster 1923 hack 1926 4 door 1926 1 ton truck
tractor conversion
Post by Gene » Fri Nov 13, 2020 8:27 am
I have a staude mke-a- tractor conversion, How do you push a 11 to 1 geared rear end if it takes a notion it won't start?
Adam
First Name: Adam
Last Name: Doleshal
Re: tractor conversion
Post by Adam » Fri Nov 13, 2020 9:09 am
Gene, Pull the spark plugs, put it in high gear, and hand crank it...
