I seem to have lost or misplaced two of my inner springs for my RAJO head. I have all the outers, VS 698 54-56 Buick, I believe will work, but short 2 on the inners.
Any ideas for the inners, will buy all 8 if needed.
Thanks, Don Vagasky
Valve Springs for BB Head
- First Name: Jeffrey
- Last Name: Hausey
Re: Valve Springs for BB Head
Chaffin?***********
I just run the single outer springs on my BB, Don - have had her revved up pretty good without any valve float.
- First Name: DAN
- Last Name: MCEACHERN
HI Don- what is your open spring pressure with and without the inner spring? Many times I find that heads are set up with way more spring pressure than needed for the RPM a T engine will be running at. Report back, but suspect that Steve might be correct. Also, checking with Mark at Chaffins to see what he uses on his heads is a good idea.
Topic author - Posts: 110
- First Name: Donald
- Last Name: Vagasky
- * REQUIRED* Type and Year of Model Ts owned: 26 Roadster 26 Touring 25TT C Cab express 26 Ames Speedster
Thanks all, I have a 30 head also on my Speedster, I will check it also.
I will give Mark a call.
Thanks again, Don
Thanks again, Don
- First Name: TIMOTHY
- Last Name: MOORE
- * REQUIRED* Type and Year of Model Ts owned: As many as can fit in the buildings, need to add on again.
Running inner springs is a good way to break the rocker arms. They were only made with one spring and all that is needed.
Tim Moore
Tim Moore
I pulled the valve cover on my speedster, it has a 30 head, same exact spring, ie wraps, OD and spring dia. No inner spring. Along with all the above inputs,......problem solved.
Now I got to find the push rods.
Thanks all, Don
Thanks all, Don
