Air filter
Air filter
Post by Steve Jelf » Sat Nov 14, 2020 12:33 am
This morning somebody in one of the FB Model T groups asked about air filters.
I didn't have a page on the subject, so I made one.
http://dauntlessgeezer.com/DG116.html
Last Name: van Ekeren
Re: Air filter
Post by Kerry » Sat Nov 14, 2020 1:53 am
Neat. :D
We don't have the luxury of room on our T's, one has to contend with the steering, :(
Last Name: Strange
Re: Air filter
Post by CudaMan » Sat Nov 14, 2020 8:52 am
Great job Steve!
I recently removed my air filter and re-installed the stock heat pipe for winter driving, but I'll be putting the air filter back on come spring.
I found a vintage Clinton lawn mower filter on Ebay, painted it black, and made an adapter cone out of brass to attach it to the carb inlet.
Last Name: Juhl
Re: Air filter
Post by Oldav8tor » Sat Nov 14, 2020 3:41 pm
Do you folks running filters find that the intake manifold beyond the carb gets really cold? I have a filter but currently run a heat pipe. I'd like to try it but have concerns about carburetor ice.
J1MGOLDEN
Last Name: Golden
Re: Air filter
Post by J1MGOLDEN » Sat Nov 14, 2020 3:48 pm
Tim, you are on to something overlooked in all the above filters.
The most important part of that original pipe is not clean air, it is hot air.
Hot air is required to prevent the center area of that carburetor icing up from the venturi effect for using the air input to suck gas out of the carb bowl.
A carb can ice up on a damp day with the temperature as low as 55 degrees or less.
Last Name: Strange
Re: Air filter
Post by CudaMan » Sat Nov 14, 2020 4:13 pm
I have not encountered icing (yet), but I definitely get condensation on the intake manifold when I run the filter.
Re: Air filter
Post by Steve Jelf » Sat Nov 14, 2020 4:14 pm
So far I haven't been bothered by carburetor ice. I wonder if the combination of warm air from the radiator and engine pans keeping out a lot of the cold air would be the reason. Of course, I'm too much of a sissy to do much cold weather driving anyway. :)
Last Name: Juhl
Re: Air filter
Post by Oldav8tor » Sat Nov 14, 2020 7:48 pm
Carburetor ice is most likely to be severe between 50° and 70° F when the humidity is above 60%. Airplanes have a control that lets you bypass the filter and duct hot air into the carb when that happens. I've experienced icing a number of times over the years usually in the spring or fall.
Dennis Prince
Last Name: Prince
Re: Air filter
Post by Dennis Prince » Sat Nov 14, 2020 9:12 pm
If you do it right you can have both hot and clean air.
Jeff5015
First Name: Jeff
Last Name: Schroeder
Re: Air filter
Post by Jeff5015 » Sun Nov 15, 2020 8:39 am
Very nice Steve, Thank you.
1916 Touring
ivaldes1
First Name: Ignacio
Last Name: Valdes
Re: Air filter
Post by ivaldes1 » Sun Nov 15, 2020 9:44 am
What does the air filter help with? Fewer oil changes, less wear?
Last Name: Strange
Re: Air filter
Post by CudaMan » Sun Nov 15, 2020 9:56 am
Hopefully less wear. I have also noticed slightly more power on climbs (seat of the pants, no hard data) due to the cooler intake charge.
I personally would not extend the oil change interval just because I was running a filter.
John.Zibell
Last Name: Zibell
Re: Air filter
Post by John.Zibell » Sun Nov 15, 2020 10:46 am
I've found this kit from Lang's works just fine. It contact the hogs head so you get some heat. I still get a little condensation on humid days, but no icing. https://www.modeltford.com/item/CARB-FILT.aspx
1926 Tudor
Mikey1968
First Name: Michael
Last Name: Jewell
Re: Air filter
Post by Mikey1968 » Mon Nov 16, 2020 10:58 am
Just wanted to warn Dennis on that clear glass fuel filter, you might want to use something else. I had one on my 68 Cougar and the O rings began to leak and caught my engine on fire. Luckily, I had a halon extinguisher handy and put it out. Just melted some wires. Swapped out that filter pronto.
Chris Barker
First Name: Chris
Last Name: Barker
Re: Air filter
Post by Chris Barker » Wed Nov 25, 2020 9:58 am
Steve,
you inspired me to sort a 'been meaning to' job.
My '26 Coupe has a Vaporizer so a different design.
I bought a dirt-bike angled filter for about $6 and I also did a bit of sheet metal work.
The tricky bit is a 'dent' on the engine side so that the choke control can operate.
No mods to the car. Doesn't seem to get hot next to the vap.
