How to install modern needle replacement in NH Carb
Quickm007
First Name: Mario
Last Name: Brossard
Post by Quickm007 » Tue Nov 17, 2020 11:29 am
Hi, I would like to install a Modern style replacement for needle and seat on my Holley NH. I never make it before. Anyone could share me the procedure as well?
NH replacement.GIF (8.58 KiB) Viewed 1973 times
Super Mario Bross ;)
1911 Touring
1914 Speedster
Re: How to install modern needle replacement in NH Carb
Post by Steve Jelf » Tue Nov 17, 2020 12:40 pm
I would not do it. Those things have a bad reputation. I would use an original float valve or a new one from Scott Conger.
Last Name: Hatch
Post by Dan Hatch » Tue Nov 17, 2020 12:57 pm
Get one of Scott’s tools for removing and installing the valve too!
Sarikatime
Last Name: Seress
Post by Sarikatime » Tue Nov 17, 2020 1:01 pm
I would highly recommend you talk to Russ Potter for guidance. He is installing two of those float valves on my two holly G carburators. As he advertises he is the King/prime authority on model T carburators. He has done great job on carburators for me in the past. Frank
Post by Jerry VanOoteghem » Tue Nov 17, 2020 1:12 pm
Check this out...
viewtopic.php?f=2&t=17110
Quickm007
First Name: Mario
Last Name: Brossard
Post by Quickm007 » Wed Nov 18, 2020 10:36 pm
Thank you all. I have the tool from Scott. Working really well. My NH come from Russ Potter as well. A friend of mine recommended to me the modern one because it avoid to be stuck as the regular needle. But I thought I will keep as is finally with the needle Russ use.
1911 Touring
1914 Speedster
