25 Drive Shaft
Topic author - Posts: 326
- First Name: GG
- Last Name: Gregory
- * REQUIRED* Type and Year of Model Ts owned: 27 Roadster
25 Drive Shaft
Are the 1925 drive shafts the same length as a 27 ?
Re: 25 Drive Shaft
Yes. While there was some design changes very early, all drive shafts are the same length.
Re: 25 Drive Shaft
***Yes.***
- First Name: GG
Re: 25 Drive Shaft
Thanks guys !
Re: 25 Drive Shaft
You should have a Ford parts book. The 1927 edition is the one to have, but I probably have over a dozen. If you would check drive shaft in your parts book, the answer would be right in front of you!
- First Name: GG
Re: 25 Drive Shaft
Except I don’t have the parts book and I like using the Forum for what it’s intended, thanks for the help
- First Name: Don
- Last Name: Allen
Re: 25 Drive Shaft
Seems to me the answer was right in front of you....on the forum.GG Gregory wrote: ↑Thu Nov 19, 2020 11:58 amExcept I don’t have the parts book and I like using the Forum for what it’s intended, thanks for the help
1924 Touring
- First Name: GG
Re: 25 Drive Shaft
There’s always a few in the crowd....always
