What is the difference between a Model T and Model A Crankshaft?
Catbird
Topic author - Posts: 46
- First Name: Bill
- Last Name: Marsh
- * REQUIRED* Type and Year of Model Ts owned: 1913 Speedster, 1914 Touring, 1923 Depot Hack, 1925 Calliope, 1926 Pickup, 1927 Speedster
I have heard about people installing a Model A crankshaft in a Model T. What are the advantages? Also, how can I tell if my 1927 Model T speedster has a Model A crank from past owners?
Bill
You can dissect a Model T; but you can’t kill it!
- First Name: Henry
- Last Name: Lee
Re: What is the difference between a Model T and Model A Crankshaft?
More torque from the stroke for sure. Larger journals, but some serious mods. Drop the inspection plate and you will know.
tman1913
- First Name: Mike
- Last Name: Bender
- * REQUIRED* Type and Year of Model Ts owned: 1913 Canadian touring, 1924 Roadster, 1926 Mercury speedster, 1927 Roadster p/u, 1920’s bobtail dirt track racer
If the front of the crankshaft at the pulley is threaded and the pan has four bumps on each side where it is bolted to the block, there’s a good chance you have a Model A crank
Remove the inspection cover and have a look
A Model crank has larger mains and rod pins along with a 1/4” longer stroke.
Take a lot more work to put one in but very doable
What Henry said. He types faster. Lol
Kevin Pharis
- First Name: Kevin
- Last Name: Pharis
Here is a pic of the pan bumps... and there will usually be a 3/8”-1/2” thick spacer between the pan and inspection cover as well
If you have the inspection pan off, and are not familiar with either crank... the A crank has circular webs near the main journals, and the T crank will look like it was bent up out out of a coat hanger
TonyB
- First Name: Tony
- Last Name: Bowker
I can usually tell if it’s an A crank by the “bumps” on the side of the pan.
Tony Bowker
La Mesa, California
La Mesa, California
Catbird
- First Name: Bill
- Last Name: Marsh
Good info! Will check into my engine.
Bill
otrcman
- First Name: Dick
- Last Name: Fischer
- * REQUIRED* Type and Year of Model Ts owned: 1912 Touring
Somebody correct me if I'm wrong, but I think one of the most significant differences is that the Model A cranks are virtually never found cracked.
Tim Rogers
- Last Name: Rogers
- Board Member Since: 2013
Model T...
Model A...
Model A...
Catbird
- First Name: Bill
- Last Name: Marsh
Thank you, Tim Rogers. Opened your post while my wife brought my coffee this morning! She also likes cars. I asked her could she see the difference between Model T and Model A crankshaft. She immediately saw the difference! She said, "The Model A looks 'newer.' "
Bill
J1MGOLDEN
- Last Name: Golden
The back Main Bearing is also shorter by about 3/8th inch.
I don't recall the exact difference.
