My Turn Signals
Mark Osterman
Last Name: Osterman
My Turn Signals
Post by Mark Osterman » Wed Nov 25, 2020 1:06 pm
I posted a short video of my turn signal system on Youtube. It is set on hazard (all lights flashing) but you get the point. My car is the standard 6 volt system. I made an adapter to hold 21 single contact bulbs in the cowl lights and smaller lights in amber lens beehive marker lights in the rear grounded through the spare tire bracket. The switch unit is a style 900 Signal Stat and I used an NOS American made ECHLIN Heavy Duty #535 flasher unit. I found that the modern #535 flasher made overseas didn’t work well or for very long.
https://youtu.be/UBz0078Ow7E
danungar
First Name: Daniel
Last Name: Ungar
* REQUIRED* Type and Year of Model Ts owned: 1922 Center Door Sedan
Re: My Turn Signals
Post by danungar » Wed Mar 24, 2021 12:52 pm
Is the switch voltage-specific? I ordered Lang's 6v turn signal kit but they said their supplier has backordered the switches for a while now. I've found some similar switches at other general automotive retailers, but all claim to be 12v. The only part of the switch I can think of that might drive voltage specification is the indicator light, which I'm guessing if incandescent would be replaceable.
Mark Nunn
Last Name: Nunn
Re: My Turn Signals
Post by Mark Nunn » Wed Mar 24, 2021 12:56 pm
The flasher needs to match your voltage. If you buy a 12V kit, you'll need to get a 6V flasher too.
Re: My Turn Signals
Post by TRDxB2 » Wed Mar 24, 2021 1:12 pm
The only apparent difference in Lang's 6V &12V turn signal kits is the flasher. This switch is voltage insensitive at 6/12 volts
Now if you intend to use LED's neither of these flashes is correct., you need a flasher for LEDs, so just by the switch and your own flasher
Retro54
First Name: Andrew
Last Name: Blaydon
Re: My Turn Signals
Post by Retro54 » Wed Mar 24, 2021 5:52 pm
Mark, may I ask, what do you use to actuate your stop light? Thanks!
