Does radiator year matter for early or late front motor mount?
ivaldes1
Topic author - Posts: 960
- First Name: Ignacio
- Last Name: Valdes
Hi all, does the kind of radiator or radiator trim matter for using a early or late front motor mount? Specifically 1916 style brass radiator with a late front motor mount?
Re: Does radiator year matter for early or late front motor mount?
That should not be a problem. 1917 still had the old type front engine mount, and the new low radiator. The later high radiator fits the same way. The only snag I can think of is the high radiator with deep apron that has the hole to screw to the engine mount will have no place to go.
MWalker
- First Name: Mike
- Last Name: Walker
The later mount should work with your brass radiator, but I'd hold out for an early-type mount because they're stronger.
You see lots of parts salads for sale that have brass radiators over 21-27 spring clips. Fit is no problem. But I would go with the earlier clip as Mike says.
- Last Name: Hatch
I just posted one for sale. Dan
kmatt2
- First Name: Kevin
- Last Name: Matthiesen
Because you are using a 1926-27 frame I wouldn't worry about using the late front motor mount you already have. If it bothers you get a early mount, be sure to get the U bolts with it. Good U bolts with good threads are the hardest part to find but out there.
kmatt2
- First Name: Kevin
Is your Y front mount part of the original T trailer ? If yes I would keep it, you have worked so hard on using other trailer parts.
Is your Y front mount part of the original T trailer?
I thought this was about a car. Why would anyone install a radiator on a trailer?
ivaldes1
- Last Name: Valdes
Brother Steve, It was a T then it was a hay wagon trailer now it is going to be a T again...
Steve Jelf wrote: ↑Sun Nov 29, 2020 2:48 pmIs your Y front mount part of the original T trailer?
Excellent! It's always good to see a T resurrected.
