Removing a Starter question
Catbird
Topic author - Posts: 46
- First Name: Bill
- Last Name: Marsh
- * REQUIRED* Type and Year of Model Ts owned: 1913 Speedster, 1914 Touring, 1923 Depot Hack, 1925 Calliope, 1926 Pickup, 1927 Speedster
Saw a video removing a starter from a car with magneto. They removed the Bendix first and then the starter. They said you should remove the Bendix before removing the starter in a car with a magneto. My car came with an Atwater Kent distributor. Would I be safe to just remove the complete starter from my car?
Bill
You can dissect a Model T; but you can’t kill it!
- First Name: Jeff
- Last Name: Humble
- Board Member Since: 2006
Re: Removing a Starter question
If the mag ring has been removed, yes, if the mag ring is still there, no.
- First Name: Jeff
- Last Name: Humble
The addition of a distributor is no indicator if the mag ring is there or not.
Piewagon
- Last Name: Regan
- * REQUIRED* Type and Year of Model Ts owned: 1911 Open Runabout, 1911 Touring, 1912 Delivery Cars (2), 1915 Roadster, 1916 Roadster, 1923 Touring Car
The simple fact REMAINS that if you attempt to remove the starter before you remove the bendix you will NOT succeed since the bendix will hit the magneto winding and you will not be able to pry it or shove it or hammer it to get it out. You MUST remove the bendix cover (4 screws) and then remove the bendix which then will allow you to remove the 4 bolts holding the starter and it will simple come right out the front side of the transmission cover. No harm done then. If you have the means of pulling your motor out of the car then go ahead and "attempt" to prove us wrong but once you damage the magneto winding ring you will find that it isn't simply a case of it not working but rather the windings will most likely get tangled up in the magnets and flywheel and you will have to pull the motor to then remove what is left of the mag ring and possibly the magnets as well. Please take the advice you have been given and abandon the idea of removing the starter if the bendix is still in place on the starter shaft.
Hope this helps.
Hope this helps.
Catbird
- First Name: Bill
- Last Name: Marsh
Thank you. Will pull the Bendix first. Looks like no big deal. I have back trouble getting in there. Will get help and do this right.
Bill
Catbird
- First Name: Bill
- Last Name: Marsh
Will do. Thanks again!Piewagon wrote: ↑Sun Nov 29, 2020 7:38 pmThe simple fact REMAINS that if you attempt to remove the starter before you remove the bendix you will NOT succeed since the bendix will hit the magneto winding and you will not be able to pry it or shove it or hammer it to get it out. You MUST remove the bendix cover (4 screws) and then remove the bendix which then will allow you to remove the 4 bolts holding the starter and it will simple come right out the front side of the transmission cover. No harm done then. If you have the means of pulling your motor out of the car then go ahead and "attempt" to prove us wrong but once you damage the magneto winding ring you will find that it isn't simply a case of it not working but rather the windings will most likely get tangled up in the magnets and flywheel and you will have to pull the motor to then remove what is left of the mag ring and possibly the magnets as well. Please take the advice you have been given and abandon the idea of removing the starter if the bendix is still in place on the starter shaft.
Hope this helps.
Bill
Will_Vanderburg
- First Name: William
- Last Name: Vanderburg
The Ford Service Manual shows how to remove the starter from the car without removing the bendix at all.
William L Vanderburg
1922 Center Door Sedan
- Last Name: van Ekeren
Not seeing that in my Ford service book Will, remove bendix then withdraw starter.
- First Name: Jeff
- Last Name: Humble
Ford Service Manual dated 1926, par 953, Removing Starting Motor from Car, states to remove the bendix cover and bendix.
Catbird
- First Name: Bill
- Last Name: Marsh
I have back problems and was hoping for a simple, quick answer. HOWEVER as most of you agree, I will remove the Bendix first, Thank you for your help.
Bill
- Last Name: Juhl
You'll need a extra long screwdriver to remove the screws that hold the cover. You might find it easier to do it from underneath. Removing the Bendix is easy, just be careful not to lose the woodruff key. Also - when reinstalling, be absolutely sure the woodruff key is properly seated.
My back isn't the greatest but I was able to do it. It is also an easy procedure to talk a willing (and more supple volunteer) through
Will_Vanderburg
I am not incorrect in what I said....
If you read paragraph 513 in the FORD SERVICE MANUAL, you can actually remove the starter and bendix as a COMPLETE UNIT.
I've actually read the book from cover to cover, so I knew it was in there.
Chapter XXX ((Model T Ford Service)
Starter Motor Overhaul
953 To Remove the starting motor from the car it is first necessary to disconnect the starting motor to switch cable (See "C" Fig. 35). Lift out mat and floor boards and remove bendix cover and bendix as described in Pars. 894, 896 and 897; the four motor mounting screws are then run out and the starting motor withdrawn.
Chapter XII
Replacing Transmission Bands
(Old Design)
513 Raise front end of the transmission cover and insert a block of wood approximately 2" thick between cover and crankcase (See "A" Fig. 300). This premits removal of starting motor and gasket "B" and Bendix "C", which can be lifted out as one unit. (Fig. 300 shows the block of wood on the starter side between the hogs head and crankcase)
953 would be for pulling the starter without removing the hogs head when quick change bands are installed (or just removing the starter).
513 would be for removing when old style bands were used and hogs head was coming off anyway to replace the bands. The key is the 2" block of wood under the corner to raise the hogs head up so the bendix could pass by the magneto coil ring.
Chapter XII
(Old Design)
Will_Vanderburg
Again... it can be done. Do I recommend it? No, I do not.
But....it CAN be done.
Along the way Ford moved from the old design to a newer design for easier starter removal as shown in the manual. I’m glad he did. it’s amazing what’s in the manual when we read ALL of it.
I had forgotten what’s in the Old design section since my 3 T’s are the newer design cars.
Now Will, of cause lifting the hogs head up will let you remove the starter as a whole but no one is going to do that just to remove a starter, are they? let alone replace it the same way
That would be a special kind of stupid
Will_Vanderburg
I said the book showed a way to remove it as a whole unit.
Sick and tired of people saying there is no way to do it other than remove the bendix. It was not my intent to tell him to remove it one way or the other... but for you people to just sit here and say that the book doesn’t say but to do it one way, is erroneous.
Now, if you’re calling me stupid, I demand you come to my house and say it to my face.
If not, then just let it go.
Unless you need to remove the hogs head, it would be harder than removing the bendix. Also it is hard to seal the hogs head to transmission and if it doesn't leak, leave it in place.
The one screw on the bendix cover which is toward the right is the hardest one to replace. If your bendix cover has slotted holes for the screws, you can start that screw first and slide the cover under it. You will need a long screwdriver especially to get that one on. Do not lose any of those 4 screws because they have an unusual size thread and hard to find replacements.
Will, I didn't say it wasn't in the service book, I said that I was not seeing it, as for calling you stupid, that would only apply to you if you are considering that removing the starter in that manor was a good idea! or recommend it to some one, as for a face to face debate on the topic, sure just pay for my plane ticket
RichardG
- Last Name: Grzegorowicz
- * REQUIRED* Type and Year of Model Ts owned: 1921 T pickup
IM WITH --U-- WILL--LETUM NOT PULL THE BENDIX LET--UM--FERGIT TO TAKE THE KEY WAY AFTER THEY WRECK THE MAG COIL,TRYING TO WIGGLE THE BOLT HEADS AROUND AND AFTER ALL THAT FIXIN THERE WAY, THAT KEY THAT THEY FERGOT WILL DESTROY THE TRANSMISSION --WHEN IT DROPS IN AND STICKS TO A MAGNET..THEN FLINGS OFF AND THAT LITTLE BAS%$$^d will destroy every thing under the hogs head, do your t a favor, remove the bendix and before removing the 4 bolts on the starter pluck that key way off and put it somewhere safe...when putting things back,put at least two bolts to hold starter then install the key and bendix-- if it drops this way it will hit the floor..
Will_Vanderburg
I turn the keyway of my starter shaft up when I install the bendix.Richard G wrote: ↑Mon Nov 30, 2020 5:01 pmIM WITH --U-- WILL--LETUM NOT PULL THE BENDIX LET--UM--FERGIT TO TAKE THE KEY WAY AFTER THEY WRECK THE MAG COIL,TRYING TO WIGGLE THE BOLT HEADS AROUND AND AFTER ALL THAT FIXIN THERE WAY, THAT KEY THAT THEY FERGOT WILL DESTROY THE TRANSMISSION --WHEN IT DROPS IN AND STICKS TO A MAGNET..THEN FLINGS OFF AND THAT LITTLE BAS%$$^d will destroy every thing under the hogs head, do your t a favor, remove the bendix and before removing the 4 bolts on the starter pluck that key way off and put it somewhere safe...when putting things back,put at least two bolts to hold starter then install the key and bendix-- if it drops this way it will hit the floor..
Will_Vanderburg
Ha ha ha. I don't have that kinda cashKerry wrote: ↑Mon Nov 30, 2020 4:20 pmWill, I didn't say it wasn't in the service book, I said that I was not seeing it, as for calling you stupid, that would only apply to you if you are considering that removing the starter in that manor was a good idea! or recommend it to some one, as for a face to face debate on the topic, sure just pay for my plane ticket![]()
Old thread supports the process "T513, describes a technique of raising the front end of the transmission cover and inserting a 2" block of wood between the cover and crankcase to permit removal of the Starter and Bendix as one unit. "Will_Vanderburg wrote: ↑Mon Nov 30, 2020 9:53 amI am not incorrect in what I said....
http://www.mtfca.com/discus/messages/59 ... 1459453224
The alternative process to not disturb the transmission cover gaskets is to slide it out - but requires removing the Bendix for clearance.
Several different processes to do it - just depends on what other maintenance is being done at the same time.
When you guys have your face-to-face debate, remember to mask up and maintain six feet.
Sounds like a plan! BTW, here's how I drain my radiator...Will_Vanderburg wrote: ↑Mon Nov 30, 2020 9:53 amI am not incorrect in what I said....
Sorry, couldn't resist.
Will_Vanderburg
It's all good. LOL
