Wire wheel spare carrier
Tmooreheadf
Last Name: Moorehead
Post by Tmooreheadf » Sun Nov 29, 2020 9:04 pm
I’m putting wire wheels on my 1924 touring. Does anyone have a good way to mount the spare on the back? I guess I could use a 27 carrier. Has anyone converted a wood wheel carrier to a wire wheel that might share a photo? Maybe I’m just over thinking this.
Last Name: Hjortnaes
Re: Wire wheel spare carrier
Post by DHort » Sun Nov 29, 2020 11:33 pm
A gooseneck is the easiest way if you can find long enuf spring clamps. Wood wheel carrier would probably require you to disconnect the body to install it.
Tmooreheadf
Post by Tmooreheadf » Mon Nov 30, 2020 6:24 pm
Yea, the gooseneck was what I was thinking, too.
Post by TRDxB2 » Mon Nov 30, 2020 6:33 pm
This goose neck comes with adapters for wood or wire wheels https://www.ebay.com/itm/Model-T-Ford-S ... SwJhhfR~-B Price is low (view USD not Canadian Dollars.) $57.80 bid and $70.09 shipping USD Ends is 16 hours I almost bought it for the price
Post by DHort » Mon Nov 30, 2020 10:30 pm
The gooseneck by itself holds a wire wheel - no adapter needed. The other Y shaped piece is attached to the short bracket and fits 21 inch wheels.
Post by RajoRacer » Mon Nov 30, 2020 10:53 pm
That's a "spool" for Runabouts & Coupes Frank - the "gooseneck" is for Tourings & Sedans and are completely different shape.
Post by TRDxB2 » Tue Dec 01, 2020 1:24 am
Steep learning curve. I thought the first picture in the ad was a goose neck. Also I added a picture that shows a bracket on the end of the neck - not sure if that's normal or if this is some aftermarket accessory of the day
so is this a different style - hard to tell from pictures
Post by DHort » Tue Dec 01, 2020 2:29 am
The bracket is not needed. That is just something the previous owner attached.
The wire wheel attaches to the gooseneck in the lower picture. No other parts needed. There originally were three thin
nuts to attach the wheel. I just used two extra lugnuts and the locking lugnut to hold the masterlock.
