Removing Sediment Bulb
BLB27
First Name: Bruce
Last Name: Brakke
Post by BLB27 » Thu Dec 03, 2020 3:56 pm
I want replace the sediment bulb from my 1927 couple, but I am concerned about damaging something when trying to get it free. I would appreciate any comments/suggestions.
jab35
Last Name: Bartsch
Re: Removing Sediment Bulb
Post by jab35 » Thu Dec 03, 2020 4:07 pm
Bruce; I use a small pipe wrench on the tank fitting and another small pipewrench/large channel lock on the bulb. I added some penetrating fluid (50-50 mix of acetone and auto transmission fluid) to my dry, empty tank and also to the outside threads several weeks prior. If you don't use the second pipe wrench on the tank fitting to resist the torque, you risk cracking the solder on the tank. Others may have better ideas, good luck, jb
First Name: Jeff
Last Name: Humble
Board Member Since: 2006
Post by Humblej » Thu Dec 03, 2020 4:17 pm
I agree, use 2 wrenches, and this is one of those situations that the blue wrench should not be used.
jiminbartow
Last Name: Patrick
Post by jiminbartow » Thu Dec 03, 2020 9:16 pm
If you use a pipe wrench you should put some sort of cushion between the teeth and the steel to prevent indentations from the teeth. Cloth or wood strips will work, 1/8” rubber strips work better. Jim Patrick
ivaldes1
First Name: Ignacio
Last Name: Valdes
Post by ivaldes1 » Thu Dec 03, 2020 11:05 pm
If you break the tank just take it to a radiator shop they'll fix it quick. Mine came to me complete with a big crack and gas leak probably from over tightening. My local radiator shop fixed it for $30.
Post by TRDxB2 » Fri Dec 04, 2020 12:20 am
agreed may want another person to hold the wrench from twisting
Altair
First Name: David
Last Name: Menzies
Board Member Since: 2012
Post by Altair » Fri Dec 04, 2020 11:55 am
I can remember some years ago I bought one of those fuel assemblies from one of the vendors and it came with some test specs that said it was tested with 10lbs pressure using water. With normal gasoline pressure it leaked even when new. I had to devise an accessory shut off.
jab35
Last Name: Bartsch
Post by jab35 » Fri Dec 04, 2020 11:14 pm
To Frank: Sorry for thread drift, but do you have a pic or description of the 'J' bolt used to secure the overflow pipe to the body? Thanks, jb
Post by TRDxB2 » Sat Dec 05, 2020 12:13 am
Langs sells a tube with the bolt kit https://www.modeltford.com/item/2921.aspx This is all I could find
26 tank.jpg (53.35 KiB) Viewed 2553 times
jab35
Last Name: Bartsch
Post by jab35 » Sat Dec 05, 2020 8:37 am
Thanks, Frank, I made a tube, just need to make the clamp. Best, jb
