Loss of power when activating horn?
Jonah D'Avella
First Name: Jonah
Last Name: D'Avella
Post by Jonah D'Avella » Wed Dec 16, 2020 5:50 pm
I hooked up a MAG horn 2 my 26 Model T. I connected the horn's body to ground and the terminal to a switch and then to the Magneto. When I ran the car on a MAG and turned on the horn, the engine died. What am I doing wrong? Is the horn taking too much of the Magneto power?
F: first F: find
O: on O: oil
R: race R: revive
D: day D: drive
Jonahdavella@gmail.com
Last Name: Hatch
Re: Loss of power when activating horn?
Post by Dan Hatch » Wed Dec 16, 2020 6:30 pm
Post a picture of your horn.
Jonah D'Avella
First Name: Jonah
Last Name: D'Avella
Post by Jonah D'Avella » Wed Dec 16, 2020 7:04 pm
Horn pictures
F: first F: find
O: on O: oil
R: race R: revive
D: day D: drive
Post by DanTreace » Wed Dec 16, 2020 7:48 pm
Guess is the horn's coil is bad and grounds out causing a direct short, taking all the AC current to ground.
Remove the cover and test the coil for conductivity at the terminals.
mag horn cover7.jpg (83.02 KiB) Viewed 3844 times
mag horn coil .jpg (86.15 KiB) Viewed 3844 times
Jonah D'Avella
First Name: Jonah
Last Name: D'Avella
Post by Jonah D'Avella » Wed Dec 16, 2020 8:01 pm
I will do that. Will it cause any damage to my Magneto?
F: first F: find
O: on O: oil
R: race R: revive
D: day D: drive
Last Name: Hatch
Post by Dan Hatch » Wed Dec 16, 2020 8:05 pm
How close is that screw to the spark plug? Is the plug shorting to horn?
ThreePedalTapDancer
First Name: Ed
Last Name: Martin
Post by ThreePedalTapDancer » Wed Dec 16, 2020 9:01 pm
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Wed Dec 16, 2020 9:07 pm
Who needs a horn..., watch for a finger!
Post by Norman Kling » Wed Dec 16, 2020 9:22 pm
If that car has a battery and a generator, it should have a battery horn.
There are only two possible reasons the horn would cause the car to stop running. One would be a very weak magneto which is right on the edge, or something in the horn circuit which is grounding the magneto when you honk the horn. It should not damage the magneto unless your spark plug is shorting against the horn circuit which could cause very high voltage to enter the magneto. If the magneto still works when you are not trying to honk the horn, it is not damaged.
Does this cause the engine to stop even when you are running at a fast speed? Or is it just at idle that it stops?
Stephen_heatherly
First Name: Stephen
Last Name: Heatherly
Post by Stephen_heatherly » Wed Dec 16, 2020 10:33 pm
That's hilarious! 🤣🤣 I use both.
Stephen
Jonah D'Avella
First Name: Jonah
Last Name: D'Avella
Post by Jonah D'Avella » Thu Dec 17, 2020 8:31 am
i will check and respond to these inquiries near noon.
F: first F: find
O: on O: oil
R: race R: revive
D: day D: drive
Post by Jerry VanOoteghem » Thu Dec 17, 2020 12:24 pm
I think the spark plug shorting to the long screw, (which should be trimmed), would simply send the high voltage directly to ground, which shouldn't hurt anything, aside from ignition in #2 ;) .
Rich Huggins
First Name: Rich
Last Name: Huggins
* REQUIRED* Type and Year of Model Ts owned: 1923 touring- 1922 deverley truck -1922 center door
Post by Rich Huggins » Fri Dec 18, 2020 8:33 am
Touch that long screw and honk the horn i bet you wont do that again
Susanne
First Name: Susanne
Last Name: Rohner
Post by Susanne » Fri Dec 18, 2020 7:11 pm
The horn won't be the only thing making noise...
:shock:
Jonah D'Avella
First Name: Jonah
Last Name: D'Avella
Post by Jonah D'Avella » Fri Dec 18, 2020 7:18 pm
I tried it on my little brother, he wasn't happy. :o
F: first F: find
O: on O: oil
R: race R: revive
D: day D: drive
