Anyone had a Spring break at the centre bolt?
Jem
Topic author - Posts: 195
- First Name: Jem
- Last Name: Bowkett
- * REQUIRED* Type and Year of Model Ts owned: 1909 Touring #9267
A friend recently hit a pothole. Stopped, couldn't see any damage. A mile later the steering locked up. The front main leaf had broken across the centre bolt hole, the 2 sides worked out of the spring clamps and the front of the car dropped down. Never heard of this before, but it is an obvious stress point for the leaf.
- Last Name: van Ekeren
Re: Anyone had a Spring break at the centre bolt?
That's why every town once had a black smith/ spring works. Springs break.
Les Schubert
- First Name: Les
- Last Name: Schubert
I had it happen on a rear taper leaf. Fortunately not the main leaf. Fortunately we have a local spring manufacturer and between us I got a new taper leaf made!!
Will_Vanderburg
- First Name: William
- Last Name: Vanderburg
I replaced a rear spring assembly because the top leaf had snapped in half.
William L Vanderburg
1922 Center Door Sedan
Charlie B in N.J.
- First Name: CHARLIE
- Last Name: BRANCA
- Board Member Since: 2010
Loose U bolts.
When T ‘s were used for everyday transportation that was fairly common. But that was over 50-60 years ago or longer.
kmatt2
- First Name: Kevin
- Last Name: Matthiesen
I have a accessory front taper leaf spring that doesn't use a center bolt. The spring uses upward facing dimples the size of the center bolt head rolled into the spring leafs. I have seen era advertising for this type spring saying, "Avoid broken spring leaf failures with our springs". So your friend's experience is Model T era perfect.
Mike Royster
- First Name: Michael
- Last Name: Royster
- * REQUIRED* Type and Year of Model Ts owned: 1915 Runabout 1916 Runabout
When I rebuilt my springs both front and rear had one spring each broken at the center bolt. Welded them up good as new.
D Stroud
- First Name: David
- Last Name: Stroud
- Board Member Since: 2011
When leaf springs break at the center bolt hole, 99% of the time it is because the center bolt isn't tight enough, and/or the spring clamp isn't tight enough. That lets the spring flex where it shouldn't. There shouldn't be ANY flex in the center of the spring. Dave
1925 mostly original coupe.
I have two 13's, and both had had the front springs replaced. I wonder if that happened often? I remember it took me over a year to find a good replacement for my roadster, but I finally did. 1913's had two styles of springs, front and rear. Some had the curled leaves and some didn't.
- Last Name: Hatch
I have a lot of them over the years. That and cracked front frame members.
Herb Iffrig
- First Name: Herb
- Last Name: Iffrig
I never have a spring break. It seems that we get busy here on the farm about then.
Jem
- First Name: Jem
Good job Herb. I was waiting for Perry to mention it.
I refrained for some reason.
I haven't had one break there but have seen a few broken ones before.
