Western Electrical gauge
Herb Iffrig
First Name: Herb
Last Name: Iffrig
Post by Herb Iffrig » Sun Jan 03, 2021 8:54 am
Is this the right gauge for a coil tester? It's a 57 miiiampere.
Western gauge.JPG (49.33 KiB) Viewed 1720 times
I just spotted it on craigslist.
First Name: Jeff
Last Name: Humble
Board Member Since: 2006
Re: Western Electrical gauge
Post by Humblej » Sun Jan 03, 2021 9:09 am
No, looks like a volt meter to me. A coil tester needs an amp meter with a scale of 0-2 amps.
Susanne
First Name: Susanne
Last Name: Rohner
Post by Susanne » Sun Jan 03, 2021 10:42 am
it dates from the right era, but is not the meter you're looking for.
This one is from the front of an electrical contactor control box... we had (maybe still have??) these in the basement of the Posey tube (built in the late 20's), it's part of the "magic" that keeps the lights on, the emergency phones working, the fire alarms ready, and the fans moving air... There were also similar control substations on either end and throughout the bridge (hidden out of sight) to control those systems (Lights, phones, fire alarms, warning systems (foghorns), etc...)
There was a switch likely below it on the face of the 6 to 8 foot tall panel box (full of electrical components and in some cases sufficiently high enough voltage to earn you a set of wings if you practice "Fingerpokken") to switch between reading voltage and milliamps.
Ours controlled the 12 KvA inputs from either side of whichever structure we were talking about, the 480 volt subsystems (lighting, emergency generation, etc.), and before they tore out the key system, the 600 volt catenary system supplying the trains. Our gauges (and boxes) were Westinghouse or GE... I'm guessing by the range (and manufacturer) of this one it's out of an old Ma Bell central office.
Herb Iffrig
First Name: Herb
Last Name: Iffrig
Post by Herb Iffrig » Sun Jan 03, 2021 4:57 pm
Thank you for the replies.
BE_ZERO_BE
First Name: BOB
Last Name: CASCISA
Post by BE_ZERO_BE » Mon Jan 04, 2021 4:39 pm
The HCCT Ammeter is a Model 156 Weston with a 0-2 Amp scale.
The Model 156 can be an AC Ammeter or an AC Voltmeter.
Most any Weston Model 156 meter can be converted to a HCCT meter.
Respectfully Submitted,
Be_Zero_Be
