Brake Pedal Problem
lmitch
First Name: Lee
Last Name: Mitchell
Brake Pedal Problem
Post by lmitch » Sat Mar 02, 2019 8:48 pm
I'm rebuilding the Hog's Head for a 1925 T. I purchased Brake & Reverse Pedal Supports, Slow Speed Notch, etc... While test fitting today I noticed there is a lot of travel in the brake pedal before engaging the cam. The wear on the pedal cam is excessive. Couldn't find a supplier that carries pedals. After a couple of hours searching these forums, I can't find a solution. Maybe I'm not using the right search phrase. Any suggestions?
First Name: Henry
Last Name: Lee
Re: Brake Pedal Problem
Post by Henry K. Lee » Sat Mar 02, 2019 9:11 pm
Mitch,
I ran it to this issue years back on the replacement pieces. Finally had to take some out of other hogsheads etc and piece them together. I have plenty of pedals and cams, but fitting really is the thing to "your" hogshead.
All the Best,
Hank in Tin-A-See
Post by Mark Gregush » Sat Mar 02, 2019 9:28 pm
Remove the shaft build up the cam by welding and file the profile back. If you are going thru all the work I hope you are replacing the shafts anyway.
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Sat Mar 02, 2019 9:41 pm
Good one Mark, I forgot to mention that!
lmitch
First Name: Lee
Last Name: Mitchell
Post by lmitch » Sat Mar 02, 2019 10:05 pm
Was hoping to just replace clutch shaft. While disassembling today it was clear the reverse and brake shaft needed replacement. The worn out bands led to over adjustment. The band ears wore on shaft threads. I'm don't believe the brakes were working when it was parked back in the 70's. If they were working, they must have made a racket. Some genius installed the bands with steel rivets and the band material was gone.
Got some good photos today but I'm stupid and cannot figure out how to post. Sized them down to 1meg.
lmitch
First Name: Lee
Last Name: Mitchell
Post by lmitch » Sat Mar 02, 2019 10:06 pm
[image][/image]
[image][/image]
MichaelPawelek
First Name: Michael
Last Name: Pawelek
Post by MichaelPawelek » Sat Mar 02, 2019 10:13 pm
Many years ago it was reported that some band material sets were being sold with brass “colored” rivets.
Unless one tested them out with a magnet they could easily be installed by mistake. Someone with experience would feel the difference bending the ears out but for someone who had never installed band linings before the switch could easily be missed.
Post by Scott_Conger » Sat Mar 02, 2019 10:27 pm
Take a few minutes now and straighten and align the pedals, too. You can work them cold just fine. The reverse pedal especially looks a little wonky unless the photo lies.
lmitch
First Name: Lee
Last Name: Mitchell
Post by lmitch » Sun Mar 03, 2019 12:21 am
You are correct. The reverse and clutch pedal need adjustment.
Post by Steve Jelf » Sun Mar 03, 2019 12:35 am
You can weld it up as Mark says, or you may find a better pedal at a swap meet. I paid $5 for one at Bakersfield.
Post by Norman Kling » Sun Mar 03, 2019 12:59 am
I agree with all the above. Also you might find that one or more pedals, usually the brake and low can be bent from pushing hard on them. It is impossible to get the right adjustment without straightening them out and if needed, weld and grind the cam portion of the pedal as Mark says.
lmitch
First Name: Lee
Last Name: Mitchell
Post by lmitch » Sun Mar 03, 2019 8:27 am
Thanks for the input. I will weld it up and tool to fit.
