HCCT Assembly Drawings Available
BE_ZERO_BE
First Name: BOB
Last Name: CASCISA
Post by BE_ZERO_BE » Thu Jan 14, 2021 9:22 pm
There is a folder in the Gallery section of the forum for HCCT information.
Martynn Vowell has been commissioned to create drawings for the Ford, KRW and Allen HCCT's.
As you know, He does great work.
Here is the link to the gallery.
app.php/gallery/album/205
There is also a second HCCT gallery labeled "MY HCCT".
You can post pictures of your HCCT albeit original, restored or homemade.
Here is the link to that gallery.
app.php/gallery/album/206
Check it out :)
Respectfully Submitted,
Be_Zero_Be
namdc3
First Name: Nikolaus
Last Name: Martin
Re: HCCT Assembly Drawings Available
Post by namdc3 » Fri Jan 15, 2021 1:45 pm
Bob,
Fantastic work, as usual. The only thing I saw on the 18z245 was that I think the original handle grips were all a constant diameter as opposed to tapering larger. With the perspective in the drawing, I can't tell for sure, but based on how the main shaft looks and that they are on the same plane in the exploded view, I think the handle grip might be modeled as a taper. The originals look at least similar to a later model T crank handle sleeve/grip. Maybe someone knows if this was a T part or just similar.
Again, this is great info and very much appreciated!
Nik
BE_ZERO_BE
First Name: BOB
Last Name: CASCISA
Post by BE_ZERO_BE » Fri Jan 15, 2021 5:24 pm
These drawings are based on hundreds and hundreds of photographs of HCCT's.
We discovered a lot of variation within each manufacturer.
We found no original drawings for any HCCT.
No drawings for any Z tool have been discovered in the Ford archives.
These drawings are the best representation of the HCCT models that we were able to determine.
There is no doubt that after more then 100 years, "Correct" has been lost to time.
Be_Zero_Be
namdc3
Last Name: Martin
Post by namdc3 » Fri Jan 15, 2021 8:05 pm
No doubt. My comment wasn't intended to cover the other manufacturers (which show many grip styles in photos and literature), but rather was specific to the 18z245. It's also possible that it is indeed modeled as a straight-sided grip and that the perspective is making it look tapered. The information you've gathered is invaluable, and I'm very grateful for it.
J1MGOLDEN
Last Name: Golden
Post by J1MGOLDEN » Sun Jan 17, 2021 3:01 pm
Very neat and great work!
Thanks Bob and Ron for the basics.
namdc3
Last Name: Martin
Post by namdc3 » Fri Mar 19, 2021 9:38 pm
This is an old post, but I wanted to correct myself for posterity. The Ford HCCT handle is indeed tapered - about 1/8". For those that haven't gone to look at all of these drawings, you should. There is a wealth of information there.
OilyBill
First Name: William
Last Name: May
Post by OilyBill » Fri Mar 19, 2021 11:37 pm
Absolutely Awesomw!
