Ultrasonic vs Vibratory Cleaner
schwabd1
First Name: David
Last Name: Schwab
Post by schwabd1 » Tue Jan 08, 2019 8:09 pm
Thinking of getting one or the other. Which one do you find most useful? What are both best used for? What media do you use? Since my use would be limited , how do the Harbor Freight units hold up for hobby use? Thanks, Dave
tdump
First Name: Mack
Last Name: Cole
Re: Ultrasonic vs Vibratory Cleaner
Post by tdump » Tue Jan 08, 2019 9:10 pm
I use the larger ultra sonic cleaner from harbor frieght to clean carbs with. Get the 2 year warrenty and use it all you want to.The 1 I am useing now in the shop is my second 1 and it has lasted 3 years or more but is coming apart at the seams. But I use it average 4 to 6 times a week. I want a bigger 1. think about the largest item you want to clean and buy what will take it in. There are some good 1's on Ebay of bigger size for around 150 I think.
jagiven
First Name: Jason
Last Name: Given
* REQUIRED* Type and Year of Model Ts owned: 26 Roadster, 25/26 speeder
Post by jagiven » Tue Jan 08, 2019 9:24 pm
I do not have an ultrasonic cleaner (yet).
I have a rock tumbler, with some type of media for de-rusting parts. Both bought from HF. It works quite well, but it takes days and days to work. When the parts come out they are very dusty. I primarily use it for bolts and the like.
First Name: Jeff
Last Name: Humble
Board Member Since: 2006
Post by Humblej » Wed Jan 09, 2019 7:39 am
I have used both. Ultrasonic is great for blind holes and close fitting parts like a clock or pen. A tumbler is great for larger holes and a lot of exposed serfaces like nuts, bolts, ammo shell casings. Both take time and are limited to small things. Most car parts I use either electrolosis or sandblasting.
