Generator bolt pattern drawing
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Thu Jan 21, 2021 4:44 pm
Just wondering if someone has a drawing of this.
I am going to machine a adapter to fit in this place and if someone has already made the drawing it will save me some time as I can just go straight to my digital readout on my drill press.
Thank you for any help!!
Les Schubert
First Name: Les
Last Name: Schubert
Re: Generator bolt pattern drawing
Post by Les Schubert » Thu Jan 21, 2021 9:19 pm
Got it solved
Got it solved
Art M
First Name: Art
Last Name: Mirtes
Post by Art M » Fri Jan 22, 2021 1:35 pm
The three bolts holes are on a bolt circle, but not evenly spaced. I will have to find my sketches from that project. I made a temporary block off plate.
Art Mirtes
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Fri Jan 22, 2021 2:05 pm
I’ve played around with Henrys engine machining a lot and have realized that virtually every thing is located by 1/16” increments. A few exceptions (like the camshaft to crankshaft spacing)!!
Post by Mark Gregush » Sat Jan 23, 2021 11:40 am
When I was making my adapter plate, I found a lot of the measurements were 1/32 too. ;)
ABoer
First Name: Anthonie
Last Name: Boer
* REQUIRED* Type and Year of Model Ts owned: 1912 touring 1923 roadster 1925 pickup
Post by ABoer » Sun Jan 24, 2021 4:06 am
Les Sch .
The distance of the Camshaft and the Crankshaft is 100 m/m
Even the Bearings of the Generator are in m/m
Why did Henry That . ???
Take Care
Toon
Bill Robinson
First Name: Bill
Last Name: Robinson
Post by Bill Robinson » Sun Jan 24, 2021 8:53 am
As Les said:
100 mm = 3 15/16 ″
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Sun Jan 24, 2021 12:21 pm
I have been promoting the 100 mm spacing for over 20 years. I figured it out when I found a very nice set of straight cut gears and realized that they weren’t a standard North American tooth, but were a perfect metric tooth profile spacing. So I made a 100 mm “link” for the line boring rig and no longer had any gear mesh issues. Before I ended up buying oversized cam gears half the time to get a decent mesh fit. The problem was that the “vertical” location of the camshaft tolerance was fairly “loose” and most line boring rigs located from the camshaft horizontally. Probably why I have never had a problem with fibre camshaft gears! The 3-15/16 spacing is.008” off. Not terrible but not great either.
To get back to my earlier comments, I had a opportunity to copy Fords factory block drawings and there I found that the bolt spacing were designed for 1/16” spacing. Your block will likely be off slightly as they had a manufacturing tolerance
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Sun Jan 24, 2021 12:26 pm
Toon
My speculation is that using the metric gear profile was to make it more difficult for the “after market” manufacturers. It was no problem for Ford to make them to the spec. This is applicable to the straight cut early gears. When they went helical they just adjusted the fit.
Dan McEachern
First Name: DAN
Last Name: MCEACHERN
Post by Dan McEachern » Sun Jan 24, 2021 2:19 pm
Yes, and pre 1926 Model T's use 762 x 88.9 mm tyres!
Post by Jerry VanOoteghem » Mon Jan 25, 2021 3:43 pm
Toon
Are you saying that the timing gears are Module gears?
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Mon Jan 25, 2021 4:49 pm
My observation is that the straight cut gears are “modular pitch”. I can’t comment on the helical gears.
