Wood suppliers
Chris Haynes
First Name: Chris
Last Name: Haynes
Wood suppliers
Post by Chris Haynes » Fri Jan 22, 2021 2:05 pm
I am looking for a supplier who can provide wood for my 1921 Runabout. The folks in Utah can never seem to get around to making it.
Last Name: Wrenn
Re: Wood suppliers
Post by TWrenn » Fri Jan 22, 2021 2:21 pm
Call Lang's. They have loads of wood, and complete body kits. Get your wallet out!! :lol:
Re: Wood suppliers
Post by DanTreace » Fri Jan 22, 2021 2:57 pm
You could try Classic Wood Products.
Website
http://www.classicwoodproductsllc.com/
IMG_4985 (600x450).jpg (128.61 KiB) Viewed 3484 times
Jahn_Wright
First Name: Jahn
Last Name: Wright
Re: Wood suppliers
Post by Jahn_Wright » Fri Jan 22, 2021 4:25 pm
I've used wood pieces for my '25 Coupe from Ford Wood in Utah and Classic Wood Products. The products from Classic Wood were the best and response to my order was very timely.
Jahn
1925 Coupe--owned by my Grandfather
Re: Wood suppliers
Post by John kuehn » Fri Jan 22, 2021 4:45 pm
Hi Chris.
I don’t know if you have had experience with the wood kits but just be aware when you get the kit you’ll probably have to do a little fit up here and there as you build it. The wood won’t usually just drop into place.
I have a 22 Roadster, 21 Touring and a late 24 Coupe. I used kits for the Touring and Roadster and a partial kit for the 24 Coupe.
Each car I had to do a little refitting here and there but after all was said and done they worked well.
I contacted the late Leon Parker who helped me to understand that Ford used different body makers for his cars and while the body metal was pretty much alike the wood structure wasn’t always the same.
The body kits will fit but it’s the details that may be a little different.
Hope this helps you. So don’t get discouraged if it happens to be the case when you get it.Good luck!
DJPeterson
First Name: Dale
Last Name: Peterson
* REQUIRED* Type and Year of Model Ts owned: 1915 Touring, 1916 Roadster, 1925 Roadster PU, 1926 Canadian Fordor, 1927 Speedster
Re: Wood suppliers
Post by DJPeterson » Fri Jan 22, 2021 6:14 pm
I used Classic Wood Products for my 26 Fordor and was very pleased, minimal adjustments and excellent fit. Only adjustments needed were to door pillars that were slightly long.
Chris Haynes
First Name: Chris
Last Name: Haynes
Re: Wood suppliers
Post by Chris Haynes » Sun Jan 24, 2021 12:33 am
Thanks to all for the information.
RichJ
First Name: Rich
Last Name: Jesteadt
* REQUIRED* Type and Year of Model Ts owned: 1914 Touring, 1913 Touring project w. "A" crank shaft
Re: Wood suppliers
Post by RichJ » Sun Jan 24, 2021 12:45 am
Classic wood products, good people to deal with, very reasonable
VowellArt
First Name: Martynn
Last Name: Vowell
Board Member Since: 2012
Re: Wood suppliers
Post by VowellArt » Sun Jan 24, 2021 12:48 am
I'd use these folks, they've been in business for well over 50 years now and their stuff fits, whereas some of the parts sold from vendors don't, without a lot of fitting.
http://fordwood.com/
Fun never quits!
Chris Haynes
First Name: Chris
Last Name: Haynes
Re: Wood suppliers
Post by Chris Haynes » Sun Jan 24, 2021 1:15 am
I have made several calls to Fordwood, left many messages. All were unanswered. When I was finally able to talk to them they weren't making any wood at that time.
VowellArt
First Name: Martynn
Last Name: Vowell
Re: Wood suppliers
Post by VowellArt » Sun Jan 24, 2021 3:40 am
Chis, they're a family owned business, sooo, if somebody gets sick, the whole bloody shop gets it too. There is also a really good chance that they're not open just now also because of all this Covid nonsense.
But their stuff is really nice, the back tack rail and backrest in my touring were made by them. Didn't even have to fit it to my tub, just slipped right in and it fit perfectly.
Fun never quits!
David Mazza
First Name: David
Last Name: Mazza
* REQUIRED* Type and Year of Model Ts owned: 1925 t runabout
Re: Wood suppliers
Post by David Mazza » Sun Jan 24, 2021 7:59 am
Fordwood, sets up the shop to build specific runs of parts or kits. They won’t begin producing a 21 roadster kit for instance until they have several orders to make sense in gearing up for it. It’s a bummer and patience is needed but when you do get through to them a do get their parts you’ll be pleased.
