Wishbone ball end
hah
Topic author - Posts: 140
- Last Name: hardiman
- * REQUIRED* Type and Year of Model Ts owned: 26 coupe
Wishbone ball end
Been prusing past post regarding ball ends. I would like to know what type of metal the originals were made of?
Sarikatime
- Last Name: Seress
Re: Wishbone ball end
What was the actual size of the ball when new. How can you replace one if the old one is worn too small? Is anyone making new balls? Frank
R.V.Anderson
- First Name: R.V.
- Last Name: Anderson
The ball was forged steel, integral with two short studs that were riveted and brazed into the ends of the tubing.
Like so many do, you failed to mention the year of your car. The design of the wishbone changed significantly over the years. The early ones are somewhat difficult to find, but if you have a late one, find another wishbone.
hah
OS car is improved..... looking for options. Could saw it off and weld another or could weld and fit to 1-1/4. Not sure which path
Is all ball ends made of the same material or did they change during a particular year? If I go the welding route it is a good idea to know what metal I am welding?
Thank you.
Thank you.
- Last Name: Hatch
There is an old post about doing this. Dan
Randall strickland
- First Name: Randall
- Last Name: Strickland
I machine the old ball off,thread post to 5/8 fine and screw on a new ball,
I checked a mint ball I have on a late wishbone, and as I recall, it is 1 1/8".
