window glass install question
lorenzo26
Topic author - Posts: 50
- First Name: lorenzo
- Last Name: leon
- * REQUIRED* Type and Year of Model Ts owned: 2 doctors coupe
I have a 26 Coupe and need the side glass and rear to mount anyone ever used the Windshield/Back Glass Ribbon Sealer
instead of the rubber from the vendors??
varmint
- First Name: Vernon
- Last Name: Worley
Re: window glass install question
I've used some, kinda like a rope of tar in a roll, on a '79 Pinto windshield. It works.
Vern (Vieux Carre)
lorenzo26
- Last Name: leon
did it look like this ?
- Attachments
- tar rope.jpg (29.87 KiB) Viewed 2548 times
- First Name: Jeff
- Last Name: Humble
- Board Member Since: 2006
It shows, you really need to use the U channel to look right.
lorenzo26
- Last Name: leon
this is side and rear glass there is no channel
varmint
- Last Name: Worley
That is what it looks like.
Our '26 coupe is not there yet. We have cut new wood for the missing and damaged wood pieces around the side windows and rear windshield, primed them but don't have the glass yet. Have not decided whether we are using black silicone, weather strip, or some other sealant yet, or what we are supposed to use. The old stuff we removed looks like black caulk.
Vern (Vieux Carre)
- First Name: Jeff
- Last Name: Humble
Channel was not descriptive, it is a U shaped rubber strip, goes all the way around the glass before you install it. The glass is constrained by the steel body on the outside, the wood frame on the sides, and the interior metal moulding on the inside. The U strip extends about 1/16 - 1/8 inch above the body and interior moulding and shows, provides a nice finished look. There is no other sealer or calking. Everything is held in place by the interior trim screws. The vendors sell the U strip, if not in the model T catalog check the model A catalog. Snyders has it, T-19003-Q.
lorenzo26
- Last Name: leon
Ok the channel is ok looks good but wont stop water unless some other sealant , i have the channel rubber and it does not
stop water by itself
varmint
- Last Name: Worley
Amazing what I just learned by online window shopping.
"Window rubber and glass channel adhesive, black, 5 oz tube"
Vern (Vieux Carre)
