Does anybody know what diameter cable was used on the original small drum AC brakes?
Stephen
AC brake cable
Stephen_heatherly
Topic author - Posts: 390
- First Name: Stephen
- Last Name: Heatherly
Re: AC brake cable
Rocky Mountain uses 3/16". If you have the pulley, that should give you a pretty good indication.
