more 26/27 fuel tank mounting questions
dmdeaton
First Name: Danny
Last Name: Deaton
Post by dmdeaton » Mon Feb 15, 2021 12:26 pm
firewall pad. Cardboard or something a little more water resistant? You guys make your own or purchase?
dmdeaton
First Name: Danny
Last Name: Deaton
Re: more 26/27 fuel tank mounting questions
Post by dmdeaton » Mon Feb 15, 2021 12:41 pm
Adam
First Name: Adam
Last Name: Doleshal
Post by Adam » Mon Feb 15, 2021 1:05 pm
Wow! Never knew anyone reproduced that AND I’m very surprised it is only $25! I’m replacing the tank in a ‘27 Tudor next month and will be ordering one!
dmdeaton
First Name: Danny
Last Name: Deaton
Post by dmdeaton » Mon Feb 15, 2021 1:39 pm
I will post a pic when I get mine.
Post by DanTreace » Mon Feb 15, 2021 3:16 pm
That molded fiberboard gas tank insulator for the '27 cars is a very nice reproduction, fits fine. The earlier Improved Car just used two strips of webbing that were riveted at 4 places to the cowl. You can tell if you car is later, as those tiny 4 holes will be missing from the upper face of the cowl.
27 cardboard tank panel.jpg (44.9 KiB) Viewed 2395 times
dmdeaton
First Name: Danny
Last Name: Deaton
Post by dmdeaton » Mon Feb 15, 2021 4:07 pm
Thanks Dan
That’s awesome
varmint
First Name: Vernon
Last Name: Worley
Post by varmint » Mon Feb 15, 2021 5:14 pm
Anyone have a photo of the two webbing strips (2917) mounted in the cowl?
I need to see whether I need to order 2917 or 2918.
Thanks!
Vern (Vieux Carre)
Post by DanTreace » Mon Feb 15, 2021 8:12 pm
These should help you, pieces for all but Fordor:
All '26-'27 used webbing pads above the tank.
Only some '26 used webbing pads behind the tank. You can tell by holes punched in the cowl face for these pair of pads.
DCP_2961 (526x478) (526x478) (526x478) (500x454) (499x453).jpg (106.95 KiB) Viewed 2311 times
The later 26-27 did away with the two webbing cowl pads, and used the molded fiberboard insulator.[/b]
above tank webbing .jpg (91.23 KiB) Viewed 2311 times
All used the rubber insulator strips on the support rods that hold the tank in place.
dmdeaton
First Name: Danny
Last Name: Deaton
Post by dmdeaton » Mon Feb 15, 2021 8:22 pm
Looks like I have the holes, and rivets are still there
So I can now say I have a 26 - not a 26/27? :D
varmint
First Name: Vernon
Last Name: Worley
Post by varmint » Mon Feb 15, 2021 9:58 pm
Excellent info. I did not even know they were there to begin with 'cause it had nothing.
I see now that even my question was wrong. Finally got 2917, 2918, and 2918A straight.
Thanks again.
Vern (Vieux Carre)
