glass
First Name: craig
Last Name: leach
glass
Post by Craig Leach » Fri Feb 19, 2021 1:40 pm
Ive never worked on early lights before where do you find glass lens's for 1914 & older headlights? Thanks
Re: glass
Post by Rich Eagle » Fri Feb 19, 2021 2:02 pm
My local glass shop cuts them round out of window glass. They do it very cheerfully when I drive there with my T.
Re: glass
Post by Steve Jelf » Fri Feb 19, 2021 2:10 pm
What Rich said. Ford didn't start using fluted lenses until 1921. For 1920 and earlier, plain window glass from your local shop is correct.
First Name: craig
Last Name: leach
Re: glass
Post by Craig Leach » Fri Feb 19, 2021 2:59 pm
Thanks guys that was easy , any chance you know what size they should be? ( dont have the pieces to put together to find out) Thanks again
Last Name: Wrenn
Re: glass
Post by TWrenn » Fri Feb 19, 2021 3:09 pm
My '13 headlamps, which are the same as a '14s, measure 7 and 3/4 inches diameter, maybe just a fuzz under to be sure.
Yours should be the same.
Re: glass
Post by TRDxB2 » Fri Feb 19, 2021 3:19 pm
Go to a Stained Glass shop that makes windows etc - they have various thickness of clear (or other if you want) glass etc. I had local shop make a speedometer lens using "lens" glass came out perfectly round and fits snug. Proper thickness is important, don't use window glass
Where are you? Profile says Laveen AZ thought you were East Coast?
First Name: craig
Last Name: leach
Re: glass
Post by Craig Leach » Sat Feb 20, 2021 10:11 am
Thanks, I'll look for a local glass shop. No Frank I'm in the southwest metro Phoenix area were it was a beautiful 70* and sunny yesterday
Thanks again.
First Name: craig
Last Name: leach
Re: glass
Post by Craig Leach » Sat Feb 20, 2021 2:12 pm
For those in phoenix Best glass is making them for me @ $21.25 each Thanks again.
Re: glass
Post by Mark Gregush » Sat Feb 20, 2021 2:42 pm
I was going to post something about thickness of the glass. 1915 up to when the fluted lens started is thicker then window pane glass, so I would think the gas light would be too. Also something to think about if you are going to use them, they get hot, would window glass even stand up to the temperature they would be exposed to?
First Name: craig
Last Name: leach
Re: glass
Post by Craig Leach » Sat Feb 20, 2021 11:31 pm
Mark you may be wrightbut window glass will reach over 140* in arizona in the summer time. I found 1926 chebby head light glass is 7 3/4" so I used one of hem I had. THe light looks OK after I got the mail box imprint out of it.
freds hl#2.jpg (22.54 KiB) Viewed 2143 times
freds HL#1.jpg (20.58 KiB) Viewed 2143 times
