Looking For A Specific Speedometer Gear
NorthSouth
Last Name: California
Post by NorthSouth » Sat Feb 20, 2021 12:30 pm
Hello Fellow Model T-ers,
Would anyone out there happen to have, or know someone who has, a #31376, 58 tooth, 8 pitch speedometer drive gear.
This was a specific hub-mounted gear made by Stewart Warner specifically for 1926/ 1927 Model T wire wheels. It is referenced on page 72 of Russ Furstnow's speedometer book.
Thank you very much for any guidance you may be able to offer.
KLTagert
First Name: Kathy
Last Name: Tagert
Re: Looking For A Specific Speedometer Gear
Post by KLTagert » Sat Feb 20, 2021 4:24 pm
You might want to check in with Russ Furstnow, he may have some extra parts, if you haven't already. Good luck.
KimDobbins
First Name: Kim
Last Name: Dobbins
Post by KimDobbins » Sat Feb 20, 2021 6:26 pm
Steve, check with Layden Butler. I sold him all me extra speedometer wheel gears a year or so ago. Kim
sportbingo
First Name: Art
Last Name: Taylor
Post by sportbingo » Sat Feb 20, 2021 6:40 pm
I have one!
sportbingo
First Name: Art
Last Name: Taylor
Post by sportbingo » Sat Feb 20, 2021 6:43 pm
Sorry it's a #30333, 58 tooth, 8 pitch speedometer drive gear.
ThreePedalTapDancer
First Name: Ed
Last Name: Martin
Post by ThreePedalTapDancer » Sat Feb 20, 2021 7:08 pm
What does the gear look like?
sportbingo
First Name: Art
Last Name: Taylor
Post by sportbingo » Sun Feb 21, 2021 6:04 pm
Steve
Attached are four pictures of the #31376, 58 tooth, 8 pitch speedometer drive gear setup. This gear is for a wire wheel 29” tire. The picture of the gear #30333, 58 tooth, 8 pitch is for a 29” tire displayed above is for a wood wheel. It looks like the wire/wood gear difference is the holes drilled in a different location. Also, the offset spacer between the gear. I hope this helps!
Good luck on your search!
Art
