1925 Model T Ford scale model running
Topic author - Posts: 473
- Last Name: Haynes
- Last Name: van Ekeren
Re: 1925 Model T Ford scale model running
I think it's BS, no way carburetor jets and fuel line that small work, just look at what is required to run a model plane and car engines.
- Last Name: Codman
I'm not so sure. I have seen models of V8 engines that small that actually did run. It's amazing that some folks have the skills to do this.
I've seen this scale model Duesenberg in person & running. If this guy can make a running Duesy on this scale, then a Model T should be a cinch. Every last detail of this Duesenberg is complete & accurate, right down to working hydraulic shock absorbers.
https://www.youtube.com/watch?v=f6TetkMpFIc
- First Name: Joseph
- Last Name: M
He says in the comments for the video;
"Hola la maqueta tiene un motor a pilas que simula el sonido del motor."
This would translate to;
"Hello, the model has a battery-powered motor that simulates the sound of the motor."
A great and very detailed model, but not a gas engine.
Wow. Thanks! He had me completely fooled, (not that he was trying to, just that I no hablo espanol).Pep C Strebeck wrote: ↑Sat Feb 20, 2021 7:22 pmHe says in the comments for the video;
I was most impressed by the low speed idle. Very difficult to do in a scale model engine, but not so hard when using an electric motor I guess.
Last edited by Jerry VanOoteghem on Sun Feb 21, 2021 3:00 pm, edited 1 time in total.
- Last Name: Wrenn
Regardless, it's pretty darned COOL!!
- First Name: Wallace
- Last Name: Bellows
- * REQUIRED* Type and Year of Model Ts owned: To Many!
Here is a link to the guys web site showing a little more detail.
https://rubenvinyolas.com/ford-model-t- ... k-up-1924/
